still crashing when opening octane render Dialog
This is a very simple file that I have attached. There are no lights and only polygons for a simple piece of funiture. Click around, hit ctrl R a few times and then try and open the Octane Dialog. It crashes for me. Please help.
- R2.zip
- (54.18 KiB) Downloaded 203 times
version? bugreport.zip? It doesn't crashes with a simple scene.
can you render somethings without crashing? i heard quadro+geforce on 340, cannot be stabile. This can be same on 337.
this is not normal. Can you try to remove quadro and go with others. Also pls try to render something in Standalone to check stabilitydive wrote:the furniture will render sometimes but if i load the dialog or itneractive render it crashes almost 100 percent
ok, try first to disable quadro for rendering. But i have a friend who has similar setup. After updating to driver 340, he had to remove quadro to work. Feedback of nvidia was that "how could you work together until today?". But i don't wanna be force to do something. But plugin is very stabile with good hardware, doesn't crashes soo much. Many crashes shows that something is wrong on your system or usage.dive wrote:Is it really necessary I pull the card out? I don't like opening up my PC. I only use it for view port, not even rendering on it. I can render on it or use it for viewport in standalone perfectly fine.
