Auto update won't work (solved)
Xertyos
Sorry, I failed to attach the file.
testscene_otoy.rar
(27.38 KiB) Downloaded 192 times
See attached file.
No attachment. You can only attach zip files and jpg/png, not pz3.
Xertyos
I've attached the zipped version in the previous post.
Thanks Xertyos. If I load that file, rotating/moving the camera using the Camera Controls or Preview Window button is work correctly, and so is moving the Daylight light in the Light Controls.
I suspect there is a conflict with another plugin you have installed. What other Poser plugins show up under Window->Addons?
Xertyos
Here's the list:
Camera Panel Plus 2014
DSON Importer
OctaneRender for Poser (obviously)
Python Shell
Reality
I suggest disabling Camera Panel Plus 2014 and Reality, and see if that fixes the problem. Also, make sure you are on the latest release of DSON.
Let me know if that works.
Xertyos
Hi Paul, I have updated DSON to 1.1.3.50 and removed Reality and Camera Panel Plus (the latter I had done before following Sam's suggestion), to no avail.
OK, I suggest reinstalling Poser and the SR's over your existing installation. That will fix up any python installation glitches which might be causing the problem.
Xertyos
Great, thanks. I'll do it.
Xertyos
Reinstalling Poser solved the problem.
I take advantage to thank Paul for the superfast and efficient support of this great plugin.
I'm a very satisfied customer. ;)
Return to “Poser”
