OctaneRender® for 3ds max® v2.04
criko3d
Hi Karba, you can render the scene without the instances..
intel core i7-4960x 3.60 ghz
32 gb ram
win 7 64 bit
1x nvidia geforce gtx 780
1x nvidia geforce GTX TITAN
DIO
RobSteady wrote:Request: Map Channels !!!!!!!
+1 !!!! :)
corei7-4930k 6 x 4,0 Ghz, 32GB RAM, 2x 980 Ti
Win7 64bit, 3dsmax 2014 / 2015
Norman_Stansfield
KARBA: First of all, don't care about sh...heads who complain over octane as "dissappointment". I switched from vray rt and there is no way back. Most of bugs come from unexperienced users who can't start to think about problem solving. Octane is almost perfect and your interactive way of small updates consulted with users on a daily basis is not common in the industry.
There is a small thing to correct which disappeared from 2.x version of 3dsmax octane:
Ability to use animated bitmaps in ifl sequence format.
I could make animated textures in 1.5 but not anymore - only first frame is loaded from sequence.
Could you please check this and fix in coming update? I believe its something easy to fix.
All the best for the whole team
keep up great work.
suvakas
Image sequence as texture works fine here with 2.x versions. Using version 2.05 atm.
Suv
mbcburt
I am using max 2014 and Hair and Fur work fine when switched to geometry. Looks like though no vertex motion blur for hair yet in 2014.
Thanks for the great updates, keep them coming.
mbc
Return to “Autodesk 3Ds Max”
