How to Network Rendering ?
(Limited 12 GPU - Including Master Station)
0. Master (C4D, Not Standalone. No Need Standalone)
Check YOUR IP Address (This is Octane Master IP. Daemon Scan Range)
1. Slave
Install octane standalone
2. Slave
Run Command Prompt(Run As Administrator)
Change Dir c:\program files\OTOY\OctaneRender 2.00\
Run Command
octane_slave --net-master-port 21000 --net-master-address Your_IP
(ex : octane_slave --net-master-port 21000 --net-master-address 192.168.0.24)
Auto Change Daemon Scan Range 192.168.0.1 ~ 192.168.0.254
3. Master
Run C4D. Open Live Viewer. Check Menu > Updates > Network Rendering
ReRun C4D. That's IT...
Thanks...Aoktar(Ahmet), Fooze
How To : Network Rendering (GPU DR)
- eyeonestudio
- Contact:
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
hi,
thanks for tips...
to easy use you create on ddesktop(or wherever) a shortcut of "octane_slave.exe"
right click on this shortcut >properties> and add in target field :" --net-master-port 21000 --net-master-address 192.168.0.xxx"
(eg:"C:\Program Files\OTOY\OctaneRender 2.00\octane_slave.exe" --net-master-port 21000 --net-master-address 192.168.0.111)
dont loose the space aftre ....\octane_slave.exe"SPACE--net-master-port....
cheers
thanks for tips...
cheers
pxlntwrk.net
pxlntwrk.net
The overhead is much worse than expected.
With a 1Gb/s network, so ~100MB/s bandwith, octane only uses about 3MB/s in each direction.
Is this a setting somewhere we missed?
SEHSUCHT Berlin - 22x GTX 780
- PavilionVL
Hello! I use Cinema 4D R15 and Octane 2 (2.03 - standalone, 2.01 - for cinema 4d). And I have 2 computers with licenses. I need use Network Render in Cinema 4D via Octane plugin for Cinema 4d.
If I do like you, then I see "Lunching bla-bla-bla...", but if I run "Start Daemon....." so I see my parametrs (port and ect.), but Octane for Cinema 4D don't use 2nd computer (write me: "other version" or "unavailble"), but I have same version.
Please, Help me!(
Please, Help me!(
abstrax did some explanation for macos, but I can't check where is thatFly wrote:Any tips on how to do that on a Mac ?
I got the network rendering working in the standalone app, but inside C4D I only get "Invalid Version" under status. Is it something to do with the C4D plugin only being version 2.03 and the standalone is version 2.04? I don't see any other 2.x versions to download for either one..
Win 8.1 | 4.1ghz 5960x | Cinema 4D R20 / 3ds Max 2018 | 2 x Titan Z + 980
Win 10 | 3.0ghz 2697 v3 | Cinema 4D R20 / 3ds Max 2018 | 4 x 980ti hydros
4 x Win 7 | 4.0ghz 5930k | 4 x Titan Black or 4 x 980ti
why? All links are there everytimes. (2.04)jblessing wrote:I got the network rendering working in the standalone app, but inside C4D I only get "Invalid Version" under status. Is it something to do with the C4D plugin only being version 2.03 and the standalone is version 2.04? I don't see any other 2.x versions to download for either one..
http://render.otoy.com/forum/viewtopic.php?f=30&t=40462
For netrender setup on macos:
http://render.otoy.com/forum/viewtopic. ... rk#p195020
