Hi
I am playing with bump maps and have noticed that the bump map doesn't line up with the image.
I have scaled both the diffuse and bump map 15 times but as you can see in the screen shot the bump map is offset from the diffuse channel.
Normal maps seem to be working fine.  I can even use the same image in both channels and get the same issue.
I am using the latest version.
