Octane Rocks !!! Navigating sucks...
giorgiomartini
Well yeah octane rocks ,but navigation with octane sucks.
maybe its me , but , do you also get to a point where no matter how much you pan , you just dont seem to move barelly ?
a zoom to selection option woud rock !!!
what do you think ?
andrian
Never had such troubles, try setting the proper units in export/import panels and all should be fine. And last, always center (zero origin) your object/scene when exporting to Octane....
Vista 64 , 2x Xeon 5440 - 24GB RAM, 1x GTX 260 & I7 3930 water cooled - 32GB RAM, 1 x GTX 480+ 1x8800 GTS 512
CGsociety gallery
My portfolio
My portfolio2 - under construction
Web site
Making of : pool scene - part1
T_England
I wouldn't say the navigation "sucks" i would say its incomplete :D
But yes i experience the same issue in Octane and other 3D apps from time to time. Usually the 3D application sets the camera pivot on the selected object, group, vertex or poly. Im not sure how Octane handles it, also im very new to octane so don't even know if you can select objects and sub-objects. But put it this way its not easy to navigate around a city and precisely position a camera to render from in its present form. (for me at least)
Thankfully the Maya exporter works really nicely for camera positioning and can play with passes that way too as a compromise while the developers work on Octanes feature set.
8Eggar8
I may be wrong, but I thought the Icon at the top sets the zoom object and resets the pivot point. No?
Left of the AF (autofocus Icon)
MSI NF980-G65 AM3 NVIDIA nForce 980a AMD Motherboard - AMD Athlon II X4 620 (Overclocked to 3.2ghz)
(2)GTX460's, (1)BFG gtx260, OCZ 60GB SSD, KINGWIN 1000W Power, HAF 932 Full Tower, XP64
Octane V1 - 2.46 - CUDA 4.11 - OBJ's from Rhino4
T_England
oh that works pretty nicely!
Hmm Its probably about time i read the manual :)
obz
The reposition button is nice for when you get lost, but the panning leaves a bit to be desired. Hopefully the rethink how it works.
Arch Linux | 1x GTX Titan 6GB + 1x GTX 780ti 3GB | 2x Xeon E5-2650 | 64GB
giorgiomartini
8Eggar8 wrote:I may be wrong, but I thought the Icon at the top sets the zoom object and resets the pivot point. No?
whats that button , the AF button ?
radiance
AF = autofocus for the camera depth of field.
guys this is all in the manual, i suggest you read it through it's not that long...
Radiance
macray
What would be really helpful is a key command that sets the view to all objects (like h, o or s in Cinema viewport; h=scene, o=object, s=selected).
No matter what I model normally I do this in mm. if this is some 30cm laptop or a 2.5km building site... - and it's a pita to navigate in Octane. Zooming takes forever with some objects.
edit: the Cinema Plugin seems to help a bit. thanks for it. Would be nice to have it mentioned somewhere and not stumble over it by accident in the forum!
Octane running @ Dell Precision laptop with nVidia quadro/ ada gpu
ahooo
it would be really nice to get something similar to the walkthrough mode in 3dsmax, which works kinda like a FPS-game.
WASD moves you around the scene, E/C moves the view up/down, Q/Z changes the speed of the navigation. Left mouse button for looking around, right mouse for panning.
