OctaneRender® for 3ds max® v2.04
coilbook
Rico_uk wrote:I would be dissapointed if it is a hardware issue, I've just bought some new cards, big PSU, motherboard, etc. If my setup isn't good enough then I don't know what system could run Octane with multiple cards.
I have the same issue, black first frame, renders freeze towards the end of a random frame in a sequence.
Hi Rico
I tried today lowering TEMP TARGET in EVGA precision (if you have evga cards) to 70c which also lowered power target to 79% and seems like it is more stable without much loss of speed. maybe if you set card setting to the max during rendering it becomes too unstable and PSUs draw way to much power than your outlet can give them. But maybe it is a lucky render when it render 300 frames before it stops.
coilbook
never mind. lowering temp did not help. plus it freezes always at the end of the frame i think software related
Elvissuperstar007
region not work
coilbook
Can anyone explain what CUDA 700 > Failed to deallocate device memory usually means?
Does card run out of memory or at the end of the frame when it freezes up it cannot dispense the processed scene. Mine does it now exactly 30 frames.
Thank you
Karba
gabrielefx wrote:Hi Karba,
you checked my scene "mylights"?
If I open the scene contained in the zip archive, that I've created for the community, and I hit "open the OctaneRender viewport" button, nothing happens.
If I hit the Render button the render starts.
Octane 2.04, Max 2014 latest update, latest drivers, etc., etc.
If I switch "on" the first ies while the Octane render buffer shows that gradient shape the render starts.
Please call these releases beta or put the daily builds in a private ftp where I (we) can have access.
Thank you.
Please let me relax a little bit during the weekends. ;)
I will check the scene next week.
Karba
coilbook wrote:never mind. lowering temp did not help. plus it freezes always at the end of the frame i think software related
By the way, Are you using 2.04 or still 2.02?
coilbook
Hi Karba I am using 2.04
coilbook
Thank you.
Thank you Karba!
I will email scene with textures through google drive to support octane as zip beginning of next week
Greg
lixai
I have a request,
OTOY needs to hire someone to help Karba with the developement of Max plugin.
He is a genius, but he needs help because he is not also superman.
So let's vote for that, i think everybody will agree.
Core i7 860, ZOTAC GTX 580 - 3GB, 2 x GTX TITAN, 32Gb RAM
Karba
lixai wrote:I have a request,
Do you have any particular complains? Something doesn't work or lack of important features?
Return to “Autodesk 3Ds Max”
