OK. That error (assuming it's the one posted above), means that the plugin is loading C:\Users\Ben\AppData\Roaming\Poser\10\rendertarget.por, and it is halting due to the file being corrupt. But you say there is no file of that name? Are you absolutely sure?
Does the plugin still open?
Can you send me the octaneplugin.log file pls (as per http://render.otoy.com/forum/viewtopic.php?f=45&t=40425)
No RenderTarget setting?
You will only have that file after you "Save as Default" from the Settings tab.I too cannot locate the rendertarget.por file on my system at all. But I'm not having problems using Octane though.
Isn't it called defaultrendertarget.por or is there a difference between the Poser versions?face_off wrote:OK. That error (assuming it's the one posted above), means that the plugin is loading C:\Users\Ben\AppData\Roaming\Poser\10\rendertarget.por, and it is halting due to the file being corrupt.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
Biffo, Zay is absolutely right - the file being loaded when the error occurs is C:\Users\Ben\AppData\Roaming\Poser\10\defaultrendertarget.por. Do you have this file on your system?
