The major change is the new logging system. It is maybe not perfect but can be used as a base. So tell, when something should change.
This release needs also an updated render properties on old scenes, which you can trigger with the same-named menu entry...
Hope you like it,
face
FIXED:
- "ApertureEdge" in the ThinLens camera shader is working.
- "Autofocus" in the ThinLens camera shader is working.
- A switch of an image texture will update the shader.
- Vertical/Horizontal Camera FOV.
- Remaining rendertime is shown in the render status.
- Current/total rendertime is shown in the info when the render is done or arborted.
- GPU memory is shown in the render status.
- Check for outside changed image files.
- "Distortion" parameter added in the ThinLens camera shader, which was announced in the RC9 release.
- The info system is complete rewritten. There are two infos which are shown.
General infos show you the current state the plugin has, like "Set Camera" or "Export Kinematics" of mesh X.
Changes will show you what is catched by the plugin. Also Kinematics changed, environment changed and so on. This can be en/disabled.
There are two places where the infos are shown. At first the status bar and the second place is in the script editor.
The status bar can´t be disabled and will ever show you infos. The script editor output can be en/disabled.
You can also set the time in ms, how long an info is shown in the status bar with the "Infobar Delay" parameter.
MANUAL
- The on-line manual is available at http://render.otoy.com/manuals/Softimage/
- Please follow the installation instructions in the on-line manual.
- This version requires video driver 337.xx or higher.
