I have found the reason of the crash
The reason is hair&fur exporter which Autodesk have provided me with doesn't like object motion blur properties even if you don't use hair and fur, see attachment.
I have contacted them about the issue, but unfortunately it takes ages to get any response from them.
What I can do at the moment:
make hair&fur support as a render option.
so by default it is switched off.
if you need hair&fur you need to switch it on and make sure you don't have any motion blur option in standard object/layer properties (not octane one), see attachment
I hope it is ok for most of you
Crash in 2.01
- rogerteddy
My scene is completely empty and it crashes in 2015. In 2014 it just dont render, but max is still working.
Any glue how to fix that?
best
rog
best
rog
- rogerteddy
I start 3dsMax, change to octane renderer, hit render or open preview. So no geometrie or material is added. It was working before. I have checked the displacement and hair, but I dont remember if it was with 2.0 or with 2.01. I guess I never used 2.0, I used the upgrade right after the purchase.
best
rog
3DSPOTFINDER.COM THE PLACE 2B43D
best
rog
HI Karba, I had the same problem last night on a newly opened max but not any more. It's difficult to debug when not constant :S I'm using max2014 sp3.Karba wrote:So you just make a new scene and it crashes?rogerteddy wrote:My scene is completely empty and it crashes in 2015. In 2014 it just dont render, but max is still working.
best
rog
using octane since the dawn of the dinosaurs
- visionmaster2
hello Karba.
not sure i understand.
i dont use Hair and fur, but all my old scene crash in max2014.
what must i do please ?
M.°
M.°
- rogerteddy
Here is a copy of my error log:
Started logging on 30.06.14 14:07:40
OctaneRender version 2.01 (2010000)
can't set empty array as animation. use clearAnim() to clear an animation.
- rogerteddy
Okay I went back to Octane3dsMaxSetup_2_0_7a and it works perfect...
