Does Octane 2.0 work with Daz Plugin 1.2
Moderator: BK
Roboman28
Currently using Octane 1.2 with Daz Plugin 1.2 and everything works fine.
I assume there is no point updating to Octane 2.0 until Daz Plugin 2.0 available.
Does Octane 2.0 with Daz Plugin 1.2 or 1.5 actually work?
dustrider
The plugins are actually compiled against the version of Octane stated, in this case 1.2. The proper dll(s) for the plugin are supplied with the plugin, and it runs indepedently of the verson of Octane stand alone you have installed.
So you can upgrade the stand alone to version 2, but the plugin will still be using version 1.2 until the updated versions of the plugin are available.
I have Octane 2.0 installed, and can still use the current 1.2 version of OCDS.
Hope this helps.
linvanchene
edited and removed by user
t_3
linvanchene wrote:If you want to use network rendering the plugins and the standalone may need to have the same version number for it to work. :!: :?:
correct. the ocds installer will (most probably) contain the octane slave version it was built for (and a gui for the daemon), and will allow a specific network node install. since there is no problem in having several different octane versions installed side by side, this should make things still easy to setup, like: run the installer and select a new folder for the ocds octane slave, and you're done...
„The obvious is that which is never seen until someone expresses it simply ‟
Return to “DAZ Studio”
