OctaneRender for AutoCAD Beta 1.20 trial comment
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
kwaikeong1402
hi Paul,
Why Octane Render for Autocad 2015 2_0_9_1 beta 64bit can't use, is there any problem?
Pls Refer attached file
Thanks.
Can you try the latest build at http://render.otoy.com/forum/viewtopic.php?f=72&t=40517 pls.
kwaikeong1402
OctaneRender for AutoCAD 2015 2.0.10.1 beta (64 bit) Ok Thanks Paul :D
kwaikeong1402
hi paul,
May I know how to export the object ID, Material ID & Alpha from OctaneRender & Autocad plugins to photoshop? :(
Thanks!!
You can render the material ID as color using the Infochannel Kernel. The Object Id is not valid in the Octane plugin, since all geometry it stored in a single mesh item when the plugin is loading the geometry into Octane. For alpha, tick the "Alpha Channel" pin in the Kernel node.
kwaikeong1402
hi Paul,
Can you give me some example, i'm not really understand.
Pls refer attached file.
Thanks you !!
kwaikeong1402
Kindly advise for the above question.Is anybody know about it?
Thank you!!
iViz3D
kwaikeong1402 wrote:Kindly advise for the above question.Is anybody know about it?
Thank you!!
As what Paul said, you can explore these features;
1. at Kernel, choose infochannel
2. then Type, choose material ID etc.
3. Then render,
4. save image in PNG or EXR
5. open in photoshop.
sample MaterialID
sample MaterialID
___________________________________
Autocad 2011/2014 Trial / 3dsmax Design 2013 /Sketchup 7/8/2013
Win 7 64-bit 16GB RAM Xeon 8-cores Quadro 4000
Alienware x51 R2 Win 8 64-bit 16GB RAM GTX670
kwaikeong1402
thanks you iViz3D :D
May I suggest reading both the plugin and Octane manuals, since this is all covered there.
Return to “Resources and Sharing”
