OctaneRender™ Standalone 2.01 - updated
roeland
Hi all,
This is an update to version 2.00, with fixes to issues reported on the forum, and better rendering performance.
Update (24 June 2014)
We have fixed an issue with the new image texture system causing a GPU crash when a scene contains image texture nodes without a file name set.
Changes since version 2.00
The rendering performance is better than version 2.00, on average we could recover roughly half the performance loss compared to version 1.55. This improvement is dependent on the scene, some scenes may not render significantly faster while others render almost as fast as in 1.55.
Other changes:
  • Fixed intermittent crashes and UI freezes when working with the node graph editor.
  • Fix crash when the FPS value is set to 0 and the shutter interval is set in percent.
  • Removed the limitation on the number of textures, the amount of textures in a scene is limited only by available GPU memory.
  • Improved rendering of motion blur on rotating objects imported from alembic files
  • Fix missing instances from scatter nodes in some scenes.
  • Small changes on how the sliders in the node inspector work: Infinite sliders, which support editing the text with a left mouse click, show a text cursor instead of a default arrow cursor. All sliders can be edited with a right mouse button click.
  • Fixed slider behaviour on translation inputs of transform3D and transform2D nodes
  • Network rendering is disabled by default.
  • Scanning for network daemons uses less network resources and is faster.
  • More clear error message when the scan finds a network slave with a different version.
  • Improved error messages when a slave process crashes.
  • Parameter "parallelism" goes now up to 8, which increases render performance by a couple percent, but you should render at least 500 samples per GPU, because caustics will take longer to appear.
Download
Windows
- 64-bit installer
- 32-bit installer
Mac OS X
- 64-bit installer
Linux
- 64-bit archive
Happy rendering,
Your OTOY NZ Team
gordonrobb
Cool. Can I just check that you mean the maximum number of textures is now no longer based on my cards maximum number, but my cards available memory?
whersmy
Whoooooooooooop! 8-)
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
abstrax
gordonrobb wrote:Cool. Can I just check that you mean the maximum number of textures is now no longer based on my cards maximum number, but my cards available memory?
Yes, that's correct. There is still a limit of 32766 nodes in the shader system itself, but that shouldn't create major issues.
prodviz
thanks for the update.
The limit for depth in PMC, is set to 32.
Is there a way or an expression to override this?
cheers,
Steve
tglaja
"Removed the limitation on the number of textures, the amount of textures in a scene is limited only by available GPU memory."
This alone makes me want to upgrade.
GTX 560 2GB, AMD FX 8350, 8GB RAM, Win7 x64
Seekerfinder
roeland wrote: [*]Small changes on how the sliders in the node inspector work: Infinite sliders, which support editing the text with a left mouse click, show a text cursor instead of a default arrow cursor. All sliders can be edited with a right mouse button click.
Oi, thanks fellas!
Seeker
resmas
Thanks Guys :D
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
enricocerica
No more texture limit !? Well this is one very good news.
I made a quick test with a scene I'm working on and I meet some issues with at least one opacity texture not working, all the others seem to work fine, strange. I tried to reload it without success, when I use the previous version it works fine. Can't give more details about this problem.
Also, no change regarding the problem I met with the previous version : http://render.otoy.com/forum/viewtopic. ... 60#p191253
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
abstrax
enricocerica wrote:No more texture limit !? Well this is one very good news.
We found an issue where "in-memory" image textures will cause the render kernel to fail. Could that be the issue here? If not, if you could provide us with an example scene we can have a closer look.
Not much we can say here. BSODs are usually caused by driver issues. Which driver did you install? Maybe try a clean install of a different one (don't forget to disable SLI afterwards). Also keep in mind that you should run the Standalone installer at least once to set up the TdrDelay correctly in the registry. Otherwise you may run into issues using displacement mapping.
Return to “Commercial Product News & Releases (Download here)”
