I seem to remember this before....not sure if it is intentional or accidental.
When picking specular colour on the glossy material....the result is the image reflects the opposite colour in the spectrum....so basically you are picking which colour gets absorbed.
Also the intensity is backwards....picking a darker colour the material shines brighter and vice versa.
This is in version 2 LW
Glossy material, reverse colour pick?
- mdharrington
Intel i7 980, 24gig DDR3, 2x GTX 470, 1x GTX 590
- mdharrington
i will as soon as i can....away from the machine right now.
- gordonrobb
I get this behaviour when the diffuse is white. Have to say though, I never use a colour for specular. Should I?
- mdharrington
here it is...
scene attached, background removed but the effect is the same
- test scene.zip
- (48.28 KiB) Downloaded 203 times
- mdharrington
this is probably something in the render itself....I seem to remember this discussion before....but it is a little weird that the color will reverse depending on the color of diffuse....
I guess in real world black absorbs everything but the color you pick...whereas white would reflect everything except the color you pick...
But this would be very confusing with image maps
- mdharrington
any ideas on this?
is this a bug, or intentional behavior?
It is intentional, because the Standalone also has this behavior. Something related to the physical shading and energy conservation perhaps?mdharrington wrote:any ideas on this?
- mdharrington
Well I am definitely not qualified to comment on energy conservation....but it seems odd that if your specularity would be close to 1 then the color absorption is reversed?
But maybe that is the way it is....I kinda slept through physics
