Hotfix update
fuzzybro
Hi all,
I have a small hotfix for you to improve stability. No big changes though, I'll try to fix all major issues next week.
Changelog
Added names to mesh nodes to simplify navigation
Fixed errors in UI and removed Debug error output
Fixed a random crash on assigning texture nodes to materials
Fixed issue that prevents to use .IES textures in materials
New builds are available on same links
http://render.otoy.com/customerdownload ... 10.520.exe
and the demos
http://render.otoy.com/downloads/octane ... 0_demo.exe
http://render.otoy.com/downloads/octane ... 4_demo.exe
Cheers
Bro
Seekerfinder
Thanks Fuzzy. It's great to see your continued commitment to the already great plugin. Keep it up!
Best,
Seeker
fuzzybro
Thanks mate!
Best things is yet to come
Seekerfinder
Can't wait. Animation would be nice.
Seeker
resmas
Thanks Fuzzy.
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
ddf
Many thanks to you, Fuzzybro! Nice work, so keep it up!)
And here's my unassuming wishlist :roll:
1. Image aspect ratio lock
2. Camera response and 32-bit EXR output
3. Exporting multiple scenes as the rendertargets at once via ocs export
4. Layers visibility and associating them with Object Layer ID channel
5. Batch render
Ваще норм плагин уже, удачи в допиливании!
Anton
Seekerfinder
Fuzzy,
For some reason neither of the 2013 or 2014 installers work for me... The installation happens seemingly without a hitch but then I still have the old plugin files in the directory... I have reported installer problems before but I think I was in the minority. Any thoughts?
Seeker
resmas
Seekerfinder wrote:Fuzzy,
Seeker
Hello there, yes I think there is a problem.
The installer puts the files in the "C:\Program Files (x86)\SketchUp\SketchUp 2014\Plugins" but it only works if they are placed in "C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools"
This is how it happens to me.
I manually placed the plugin folder files in the Tools Folder and it works.
cheers
resmas
Seekerfinder
resmas wrote: I manually placed the plugin folder files in the Tools Folder and it works.
Hey Resmas,
This is not the case with me. In my case, there is no installation of the new files at all - even in the Tools folder. Incidentally, all my plugins work just fine from either the Plugins or the Tools folder (though Octane sub-menu is still under the Plugin's folder inside SU...?)
Fuzzy,
Could you post the install files as an alternative?
Seeker
resmas
Hello again mate, when running the installer I have to set the directory where to install. The default option of the installer is C:\ProgramData\Sketchup|Sketchup 2014.... in my computer its not this directory. If I run the installer as default setting, it installs but doesn't show up in SU... the problem might be here C:\ProgramData\.
Lets see if Fuzzy can sort this.
cheers
resmas
Return to “SketchUp”
