Octane 2.0 only texture displacement?
riggles
Using the 2.0 Standalone, I tried testing out the new displacement feature. However, I'm unable to connect a turbulence node to the displacement pin. Changing the displacement texture pin in the material to other procedural textures has no effect on the preview. Loading a grayscale image into the displacement worked fine, however.
Is the 2.0 displacement feature limited to only texture map sources? The features list says: "...displacement mapping allows the height of points on a surface to be adjusted based on an image value.", so I guess no procedural displacement?
decade
Here's what the new manual's 'release notes' says:
◾Displacement mapping
For giving objects depth and detail, a new pin is added in the material nodes allows the height of points on a surface to be adjusted based on an image value. Displacement mapping is currently limited to image textures and UV mapping.
So basically, you're right.
riggles
Ah, hadn't seen the manual. Ok, thanks.
I'd be a bit more bummed, but I realized that even if procedural textures were supported, Octane doesn't even have enough procedurals to be useful in most displacement situations for me anyway.
daveyt
Can you tell me where to find the new manual?
Only see old one, I'm sure its right in front of me!!
gtx 580 3gb gtx 660ti 3gb win 7 blender 2.65
FooZe
daveyt wrote:Can you tell me where to find the new manual?
http://render.otoy.com/manuals/Standalone_2_0/
brasco
Is the invert node working with Disp? It doesn't seem to work for me.
cheers
brasc
Rig#1 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 7900K 4.7GHz | 64GB
Rig#2 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 3930K 4.4GHz | 32GB
Rig#3 Win 10 x64 | GTX 1070| GTX 1070| GTX 1070| i7 2600K 4.8GHz | 32GB
voon
Does that make sense? I thought a turbulence node is also just a normal texture ... precalculated and procedural, but still a texture?
this is not big trouble, because displacement is based on textures.
voon
It would be nice to be able to use the procedural textures, thou. Or in a more distant update, the colormapped directional displacement. :-)
