Hey mate,
just playing with version 1.02 RC7 in Softimage 2015 and can't get geometry instances generated in ICE to render. ("Set-Instance-Geometry" node.)
If I create an instance with Edit-Duplicate-Instantiate, the resulting instances render OK.
Is this a limitation of the plug-in, or is their a technique I'm missing?
Cheers,
Sandy
ICE Instances
ICE is on the plan to implement the next time.Sandrust wrote:Hey mate,
Cheers,
Sandy
But before i will implement shader compounds and bring back the material preview.
The only solution for now is to use a plugin to convert ICE into real geometry...
Sorry for that.
face
http://vimeo.com/user2509578
Hi Sandy,Sandrust wrote:Thanks face. No problems.
Can you recommend a plugin to convert the ICE instances into geometry?
Cheers,
Sandy
one of the best with many other options is the emTopolizer from my friend Eric Mootz:
http://www.mootzoid.com/plugin/emtopolizer2
But there are some other which are free.
One from Guillaume Laforge:
http://www.si-community.com/community/v ... =15&t=1579
And one from Grahame Fuller:
http://www.si-community.com/community/v ... =19&t=3588
Hope this helps,
face
