Displacement tips
Chris
Lets say you make a simple wall with beveled corners and apply a material with displacement, you have have probably noticed that along the edges the wall will split up. The solution is to put every polygon in the same smoothing group ;)
Displacement works awesome by they way ;) Nearly no performance loss when using it.
________________________________________________________
Win 7 64 | 1x GeForce GTX Titan | AMD Phenom II X6 3.20Ghz | 16GB
Return to “Autodesk 3Ds Max”
