Version 1.54.2 (Octane Render 1.54) *** 03.06.2014 ***
- AndreaMannori
The first time it happened after applying a material, few seconds after; the second time happened exactly applying a material. I'm not a programmer so I can't go deeper but I can try to describe you what's happening here each time
Andrea Mannori
win 8.1 x64; nvidia 770M driver 340.52; octane standalone 2 + c4doctane 2.
of course, i'm asking to give me some clue. I can't help with this general info. Need more spesific data.renderfarmsrl wrote:The first time it happened after applying a material, few seconds after; the second time happened exactly applying a material. I'm not a programmer so I can't go deeper but I can try to describe you what's happening here each time
Best
- wireframex
It works now with new drivers (337.88)aoktar wrote:can you try to update your nvidia drivers. I forget to add some note, this version has 750Ti(Maxwell) gpu support. You may need a never graphics card driver.wireframex wrote: Same with 1.54.1 it doesnt find any GPU ...If I come back to 1.53.1 all is ok
Phil
Thanks aoktar
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 560.70 - Octane Plugin Build 2023.1.3.141
Licensed: Softimage 2012 SP1 / Lightwave 2024.0.1 / Rhino 8.9
HUGE agreement with Lucioing. LOVE this new check box! Do you know how much time that is going to save us? It's better than the MAX solution. It just works. THANK YOU!!!!lucioing wrote:I want thank you for the useful Perspective correction: it's very, very useful!
Thank you again, Ahmet!
L.![]()
alec
Alec Syme
http://www.fuseanimation.com
-Gigabyte X79-UP4 - Intel i7 3930 3.4 - Windows 8.1 Pro 64bit - EVGA TITAN X7 - 32 Gigs Corsair 1600 4 channel RAM -
- AndreaMannori
here's a screen capture of what happens with a very basic scene
- Capture 01.mp4
- C4D not responding
- (6.99 MiB) Downloaded 6235 times
Andrea Mannori
I get a
"CUDA driver version is too low - can't use CUDA"
Error, LiveViewer stays black, when starting 1.54.1/2 in R14 on a GTX 780 still using driver 327.23. c4doctane 1.53.1 is working.
Is it due to driver? Wich one is stable now?
Ah, found it. I'll take this one
http://render.otoy.com/forum/viewtopic. ... 56#p187360
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
it's a crash. But doesn't give any idea what trigger this. Need more details about problem.renderfarmsrl wrote:here's a screen capture of what happens with a very basic scene
