thanks! To get a full screen, select fullsecreen menu item and close live viewer. And reopen it. You should see it as without any window bar. Ctrl+Tab will make it full screen. To locate in second window, you must move it to second screen by resizing. You can disable all on-screen info from settings window.itaki wrote:Love this release, but can't figure out how to make the full screen viewer open on my 2nd monitor. When I go full screen it just opens right on top of my main screen in a window. Is there a screen selection mode or something?
Version 1.54.2 (Octane Render 1.54) *** 03.06.2014 ***
I guess that's what the problem is. There's no handles to resize. I can't grab the window. Maybe it's a Mac related issue. Are you on a PC? I've tried everything I can to move it. Maybe I'm missing something?
16 core Mac Pro. 32GB. 2 x GTX 690. C4D.
yes, i'm on windows. Maybe a problem for macos. I'll check it, sorryitaki wrote:I guess that's what the problem is. There's no handles to resize. I can't grab the window. Maybe it's a Mac related issue. Are you on a PC? I've tried everything I can to move it. Maybe I'm missing something?
Thanks for update Aoktar. It's much more stable than the previous update but there is one problem. x-particles doesn't work anymore. It crashes everytime i open LV and i have a x-particles system opened. I tried to put object tag on emitter, but still crashes. It would be great if you could fix this. Thanks
-i installed 1.53 and it still crashes on x-particles, which didn't before. This is strange. Am i doing something wrong? Does x-particles work for you guys?
i7 4770k, GTX780, 16gb ddr
hi,lucioing wrote:Here I'm...
Maybe, the pick focus doesn't works on live view...
L.
i can confirm that there is an issue with the live view and mouse picking in the last mac version.
no focus, no material picking and also no right click menu, it seems that the color picker is always active
ciao beppe
...I was beginning to believe that it was only a problem mine...bepeg4d wrote:hi,lucioing wrote:Here I'm...
L.
no focus, no material picking and also no right click menu, it seems that the color picker is always active![]()
ciao beppe
https://dl.dropboxusercontent.com/u/241 ... 0focus.mov
L.
Mac Pro 5.1 -16 GB- 2 x Titan Black 6GB - Titan Z - MacOS Yosemite 10.10.4
ok, thanks. I think there is a problem with new code on MacosX
Hi!
Playing with Octane stand alone, I could try the 'Perspective correction' button: very, very cool !!!
Do you think, Ahmet, to implement it?
Thank you
L.
Thank you
L.
it's just a parameter on octane camera tag, you should see therelucioing wrote:Hi!
Thank you
L.
No, I can't! Maybe in Win version...aoktar wrote:it's just a parameter on octane camera tag, you should see therelucioing wrote:Hi!
Thank you
L.
L.
