Lighting Question
jbsfender
I am currently working on a project that requires a building to be shown at night with these LED lights illuminating it. How do you think is the best way of going about this?
I have tried having IES lights but the light doesn't go very far and if I turn up the intensity too high you get it burning out at the source. I tried this with having invisible Octane lights going up the wall but you could see any colour difference between the lights. There are about 15 bulbs close together and each one has to be a different colour and look like the examples attached.
Any ideas would be much appreciated.
Olitech
IES emitters or lights would be the easiest way, but you will have to make sure you are using an IES map with the correct spread for this situation.
best,
O
WORKSTATION = Win7x64 / Intel Core i7-5930K [email protected] / 32GB ram / Liquid Cooled 4xTitanX /3dsMax 2014 / Octane Max Plug v2.16a / FARM = Intel i7-2600k 3.70GHz (x2 TitanZ) x 14
remKa
Exactly,
you have to use a nice ies file in your Octane IES Light.
Play with the gamma to get sharper details.
http://mayazest.blogspot.fr/2012/02/fre ... files.html
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
jbsfender
Thanks for the advice guys. I have that set of IES, which number did you use for your example? Looks exactly what I am after!
remKa
18.ies ;)
Return to “Works In Progress”
