OctaneRender for AutoCAD Beta 1.55 [OBSOLETE]
Autodesk AutoCAD (Integrated Plugin developed by OTOY, maintained by Paul Kinnane)
guillerodriguezv
It is OctaneRender for AutoCAD 2014 1.52.0.6 beta (64 bit)
Please check the link for the ACAD 2015 Octane plugin
Guillermo
Laptop- Win 10 64- 32 Gig GTX 880m 8 Gig - Desktop Win 10 64- 16 Gig GTX 980 ti 8 Gig
Guillermo, I think there was a problem with the installer, which I will fix today. I also have Polyface Mesh objects loading into Octane (for AutoCAD 2013 - haven't tried 2014 or 2015 yet), however there are no vertex normals provided by AutoCAD for these objects, so you need to turn OFF "Smooth" for each material. I will post updated installers in the net 8hrs.
1.53.1.8
- Compiled against Octane 1.53.1
- Fixed issue preventing Polyface Mesh objects from being loaded. NOTE: Normals are NOT provided by AutoCAD for these objects, so DISABLE SMOOTHING for all materials of these objects
- Changed installer so that the 2013, 2014 and 2015 version of the plugin install into separate folders in the OctaneRender for AutoCAD.bundle\Contents\Windows\ folder
- Fixed minor installer issue which required an uninstall prior to installing a previous version
- Added AutoCAD 2015 installer (type the command OCTANERENDER to start the plugin)
- Removed 32 bit installers (since no on appears to be using the 32bit)
guillerodriguezv
Hi Paul
Octane Plugin for ACAD 2015 does not load in AutoCAD 2015, when I write OCTANERENDER in the command line it answers "command unknown", please check it.
Octane Plugin for ACAD 2014 works great.
Guillermo
Hi Guillermo - I found a problem with the installer, which I have now fixed. Can you pls re-download from the link at the top of this thread (version number has not changed) and install again and it should hopefully now work.
guillerodriguezv
Hi Paul
Octane Render Plugin for ACAD 2015 works great I will do more testing and check it more deeply.
Guillermo
1.55.0.8
- Compiled against Octane 1.55
guillerodriguezv
Hi Paul
What is the difference between version 2.0 and version 1.55 with the AutoCAD plugin ??
Guillermo
Pls see the Octane 2.0 implementation details for the AutoCAD plugin at http://render.otoy.com/manuals/AutoCAD/?page_id=661.
guillerodriguezv
Hi Paul
I got problems with the latest plugin version 1.55, it seems that it does not save materials, and it shows this message when I open the plugin tab, also it never stops showing the message loading materials. At the end it does not load the saved materials.Please check.
Guillermo R.
Never stops loading
Never stops loading
Message when plugin start
Return to “Autodesk AutoCAD”
