IES lights in blender
vimaxus
Can someone please enlighten me as to how can I use IES lights in blender octane edition?
The manual is a little skim:
Distribution – The distribution controls the pattern of the light. This can be set to an floattexture and an image or IES file can be loaded.
No octane texture allows an IES to be loaded apparently.
kavorka
in the standalone you need to load up a float image, I think it is called a greyscale image now
aufwind
Node Setup for ies:
To load the ies file make sure you disable file filtering option:
mib2berlin
Hi, you can add "Spherical Projection" and "Rotation" to get full control over your IES light.
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
vimaxus
Thanks guys!
It was mainly the filtering thingie that was preventing me to use it.
Maybe it should be added to the manual...
ROUBAL
Hi, thank you for this setup. I have only used IES in standalone so far, but these infos will be very useful when I'll use the plugin !
Return to “Blender”
