Here are my final images of the scene ("Long cable scene") i posted in last days in the WIP-forum.
Maybe i will make some more shots of the unshown parts.
The chair - interior (long cable scene)
http://www.C9W.de - Win10 - Dual E5 2620v3 - Display 1 GTX 1080 / Render 1 3090 RTX - 96 RAM - C4D MSA - C4D Plugin version: current - Standalone: current
Good job... I like the light ambience and perspective you have chosen.
Did a spider took that one picture while balancing on the cable
I like them all except for the one with the ashtray.
(just kiddin.. I do not smoke anymore, that's why
I could see some noise on the render... did you have no time to render them longer or is there another reason?
greetz,
greetz,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
Hi Rappet,
first: thanks for your comment!
I rendered nearly 3 hrs each on two GTX 780s for 3200 samples PT. I know that there is still a lot of noise, especially in the difficult areas on the walls. But I think this are imperfections which might appear in real-world-photography too. So the bloom and DOF does. I, personally like the noise in some cases. There are artists adding some grain to there works. Others doesn´t.
Hotpixels, white spots, on glassmaterials or something like that are different. They are not very nice... So, I differentiate between noise/grain and hotpixels. What is your opinion?
To get these images noisefree i would have had to let them run minimum 4x the time. No option.
i don´t know the photographer, perhaps it was Mr. Spider...
and to be political correct i should have changed the ashtray against an fresh, green apple. Please don´t smoke kids!
I totally agree on the hotpixels/grain aspect
noisy and very nice images.
Thank you aoktar.
Perhaps i should have rendered the images a bit longer for less noise. There was no need to render in 3000px, so 2000px would have reached over 6500 samples in the same time. I gave it a try and simply reduced one images´size to 2000px and i guess it is better. I need some good denoisesoftware... any suggestions?
I use Photopaint (Corel) and a lot others probably use Photoshop,Chriz wrote:Thank you aoktar.
but you can also use GIMP (it is free) and remove noise:
http://www.gimp.org/tutorials/Selective_Gaussian_Blur/
greetz,
