How to make a Spotlight or Volumetric light ?
in theory, the big fog volume is no more needed if you use the inverted sphere attached to the camera, because all the things behind the sphere will be affected by the fog, unless you don't need to set a specific place for the fog ;)
ciao beppe
atome451
You are right bepeg. It's even possible to use planes facing to camera to control the fog in depth.
I'm maybe wrong but i always use a very big cube to give an end to the fog because i have the feeling it speed up the rendering a little bit.
I also always use a cube with only one polygon by face and not a sphere (with inverted normals as explained above) because it really speeds up the rendering (not just a feeling in this case :D ). Like with emiters, less polygons is better.
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
Kalua
Here is an alternative:
https://gumroad.com/idani_4dm#
Look for this:
4DM_Cinema4D_Octane_Lights
It automates the creation of spotlights in C4D and some other things for Octane,... and its free
Cheers!
C4D 2025.1.1 Octane 2025.2.1 v1.5.1, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 552.22
