For now, move your camera to a separate layer and just export that layer, that is how I am getting around it.resmas wrote:Thanks Jim for the hard work.![]()
Just one question, when i export a camera animation, i set Animation Mode to "Camera Only", and i check the box "export alembic". The alembic file ok, but is created with geometry.
When i open it in OctaneStandalone it has all geometry pins - so i go to alembic file option and uncheck "load geometry" to have a camera animation alembic file.
Camera animations exported to alembic, from Maya have around 150kb. The alembic file exported from blender has 100mb, because it has geometry when I only want the camera parameters.
While blender is exporting the animated camera I can see that its reading/exporting geometry when I set to "Camera Only" and for 500frames it takes about 5 minuts, in Maya it take 5 secunds (no geometry export)
I'm I doing something wrong in the export process?![]()
cheers
resmas
OctaneRender™ for Blender 1.52 - 4.7 beta Win [OBSOLETE]
hello mate, i just found that now too
resmas
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
Too many materials in Octane standalone.
In Blender (Octane) not save animation ...
Even render..
Even render..
- test.blend
- (526.02 KiB) Downloaded 209 times
Intel Core i7_870 | Win7 64 | 8 GB ram | GTX760 x Octane | SketchUp 2013 | GIMP |
Ah, ok .... There was no material Octane Blender, sorry.
- test.blend
- (545.43 KiB) Downloaded 228 times
@Natato : Tested your last blend file : exported two materials pins, 100 frames anim works fine.
