Version 1.52.1 (Octane Render 1.52) *** 10.04.2014 ***
virtualzapp
Hi Aoktar,
On Mac version, I can't import a orbx file I have created on the 1.51 standalone version.
C4D put me this in the console:
Octane: importORBX mat:0x0000000000000000
Any idea on the problem?
Thanks and Regards
Regis
VFX compositor / CG generalist
Mac Pro 12C 2.93GHz, 64gb ram, 1xGTX Titan X, 4xGTX Titans in Cubix
virtualzapp wrote:Hi Aoktar,
Thanks and Regards
Regis
is it working on files that are created by 1.52's Standalone?
virtualzapp
Thanks and Regards
Regis
Same issue ;o(
shawnfrueh
Hey Aoktar I found something weird about the Environment Tag, 1.52.1. When changing the color or HDRI, some of the data does not get removed:
Some projects I have had over 50 RgbSpectrums or ImageTextures attached to the Tag.
Shawn, where do you look this?
virtualzapp, I'll check import orbx
shawnfrueh
aoktar wrote:Shawn, where do you look this?
Set your timeline to automatic mode and check "link view to object manager" Then select the octane sky and it should show up in the timeline.
ok, allright. Preset buttons doesn't clean old node. I'll try to fix it
hi,
under osx, with 1.52, the emitters have no shadow.
here is the same scene opened with 1.51 and 1.52:
152-shadow_0001.c4d.zip
(61.83 KiB) Downloaded 286 times
ciao beppe
indexofrefraction
hi aoktar…
i just add something i noticed here :
if you use the octane imagetexture nodes for textures, they are missing in the texture manager !
thats a bit sad because the (great!) functionality of the texture manager is broken…
does it make a difference for octane if you use the internal texture node?
:) cheers!
Mac Pro (2012) 2x6 Core | 24GB | 1 x Geforce GTX580/3GB
brasco
Latest version 1.52.1, seems to not use GPU high priority when rendering to picture viewer, it works fine in Live viewer though.
edit: Ignore that, I just found my GPU wasn't boosting properly since the resolution was too low, apologies, it's working fine now.
cheers
brasc
Rig#1 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 7900K 4.7GHz | 64GB
Rig#2 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 3930K 4.4GHz | 32GB
Rig#3 Win 10 x64 | GTX 1070| GTX 1070| GTX 1070| i7 2600K 4.8GHz | 32GB
