Camera Path Animation
MB
The need to be created in the modelling application, you will probabaly have to write a script for that too.
there is one posted on this thread for Rhino.
best
kavorka
Is there one for Blender by chance?
As of right now, I am trying to get my camera path out of Blender into the stand alone but the Alembic export/import somehow messes it up.
gmillas
I have create a plugin for rhino that uses curves and point int camera frames
it is posted above
MB
gmillas
Would it be possible for u to fix the path output to ffmpeg in your cool app to be able to handle file names and folder names with spaces in them, this would help a lot.
Thx
mark
gmillas
I 'll give a shot. I think its easy
8-)
MB
Did it turn out to be harder than you thought?
thx
BroAugustine
MB & gmillas,
Handling of space values for os.execute() is a bit tricky.
If you replace line 660 thru 671 in the latest script with the following, things should work.
Cheers
function ffmpeg()
    if OUT_PATH == nil then
        return 0
    end
    FORMAT=formatComboBox:getProperties().items[formatComboBox:getProperties().selectedIx]
    FPS=frameRateSlider:getProperties().value
    scriptDir = octane.file.getSpecialDirectories()["userScriptDirectory"]
    local octane_dir=[["]]..scriptDir.."\\ffmpeg.exe"..[["]]
    local ffmpeg_cmd = octane_dir .. " -i \"".. OUT_PATH .."\"".."%04d.png  -c:v libx264 -r ".. FPS .." -pix_fmt yuv420p ".."\"".. OUT_PATH .."." .. FORMAT.."\""
    local cmd = ffmpeg_cmd:gsub("\\",  "/")
    os.execute([["]]..cmd..[["]])
end
Win 7 64 | I7-2600K 3.7 GHz | GTX 460, GTX 760 / Driver 347.09 | Cuda 7.0.18
gmillas
Thanks for the addition
MB
Many many thanks :D
erges
Hi, Please, How to create the camera path in Maya? Is there the plugin or mel script?
Return to “Lua Scripting”
