Ambient occlusion intensity
if you mean colors, AO has only size parameter, not has a color option. You should try other factors to colorize your scene
why isn't helpfull. It's a standart parameter for affected range of ao calculation. It's in meter. Be sure you didn't select DIFFUSE in Gi_mode
Yes, with Aodist I can ajust range of AO calculation, but not intensity. What If I need calculate AO with wide range, but leave it more darker? Besause if I increase Aodist automaticly reduce saturation of AO. Maybe physically this is correct, but what if I need to fake a little
Win7, i7 950, 12Gb RAM, GTX580
understand, 2.0 has AO pass, and full set will come later. But on 1.52, you may try cameraimager to set gamma or so.
