I am thinking to double my GPU power by adding two Titans in my second PC.
The mobo is a MSI X58 Pro-E and it has already a gtx275 in the first slot.
The plan is to fill the other two slots with Titans
This is a link to the mobo:
http://www.google.nl/search?q=msi+x58+p ... qBZ8UNM%3A
I know the pcie is 2.0 and not 3.0, but I understand that has only effect on loading the scene (half speed) and not does not effect the renderspeeed. I'll accept this downside as pro ofr my wallet not having to spent money on a new config
The 900Watt Power should be enough, right?
The thing I am worried about is the heat. I have a Coolermaster CM 690, but only with one fan on the side and one on the back. Should I try and addd more fans when have added the Titans?
I have to re-direct the powercable from PU to mobo, but I must be able to mange that.
The Lan is 1gB. Are there more specs I need to pay attention to, when I want to use the PC for network rendering (hopefully in the near future
At this moment my main PC has 4x580's and Has a optimal aircooling for the lot of heat.
First I was thinking about swap two 580 with two Titans (I want to buy) to boost my power on the one machien,
And add the two 580 in my second machine.
but I think adding two 580's in my second machine (with X58) is not such a good idea, because of the heating problem. If I am right the Titans produce a lot less heat.
Comment and advice is very welcome.
Greetz,
