render animation with alpha
Is it possible to save my animation as quicktime or avi with alpha hdri? I want the hdri to cast light on my object but not to be visible in the animation. I know that i can have that if i save as png, but does it work with quicktime or avi? Thanks
i7 4770k, GTX780, 16gb ddr
i'm not sure that understand exactly you. You can save outputs whatever you want. But did you tried to do something or checked in liveviewer? Kernels has "enable alpha" and "keep environment" options. this is the ways to get images with alpha. What is the alpha with hdri?
hi pavel,
as far as i know, quicktime can save a .mov with alpha only with the "animation" codec, sorry i don't know anything about avi
ciao beppe
ciao beppe
Somehow i forgot to uncheck keep background, and now i do not see the hdri anymore, which is good, but i have a black background instead of alpha. I have tried both quicktime animation and avi unconpressed.
I have attached the scene, in case anyone has time to check it. Sorry guys, i am sure it's very easy but i am pretty new to 3D and i don't know much.
- alpha test.rar
- (24.38 MiB) Downloaded 274 times
As people already said to you, you should make an image sequence (png with RGBA enabled, or maybe .tif),
Then in After effects or any video editing package, you can import this images sequence and render it as quicktime movie ( with "animation" codec, that indeed supports alpha channels).
Using sequences is a good practice because you separate the 3d rendering and video encoding tasks.
Titan Black + GTX 580-3go / Win 7 pro 64 bits / C4DR14 with integrated plugin / Blender / Octane standalone /
website : http://www.kiwimage.com
Render the whole scene normally with HDRI.
Than turn off octane render in settings, get rid of HDRI and do a separate alpha. This render will take you few minutes/secconds.
In any kind of compositing program you'll be able to use the alpha map for your footage.
Or use multipass.
Or use multipass.
