Hi Slepy8
Its is hard to do all things to work, but it is possible...
In that scene, all the plants are in 3D, grass, flowers, trees, etc...
They are all scattered with forestpack...
I don´t know how much geometry it has but my Titans are at the limit... sometimes they even crash before the render... it is a tricky scene.
I am dreaming about the 800 series... sometime ago i read that they are going to launch the GTX 880 card with 12gb (not like the overpriced and overestimated, titan z, that have 2 GPU´s with 6gb each)...
Fábio
Terroir Vines
- FabioHartmannFernandes
Last edited by FabioHartmannFernandes on Wed Apr 02, 2014 10:16 pm, edited 2 times in total.
I am absolutely in love with your lighting, not to mention the the way your trees look in the it! I never seem to be able to get my trees to look like that in my scenes. Would you be willing to share the material settings with the rest of us? Or provide some tips on how you approached setting them up?
Intel Core i7 CPU 6850K @ 3.60GHz 128.0 GB Ram / Win 10 64 bit / 1x GeForce RTX 3080
Hi Draydin
I´ve used one HDRI map for the entire ilumination... with gamma set to 1.6 to give more hard shadows...
In the trees i used a material for the leaves with the transmission set with the same map, but 2 times more brightness (brightness scale on color correct map)...
Hope i helped...
Cheers
Fábio
Hope i helped...
Cheers
Fábio
Hi Vaughan
I´ve reached the Titan VRAM limit some times... i had to create several layers for the furniture, vases, cars, etc... and for each camera had to set the layers accordingly with what needed to be shown.... and i have done a huge cleaning on the maps to stay under 144 textures... i´ve used diffuse maps mostly... i had to skip bump maps, reflection maps, to make the scene work.
Fabio
Fabio
