OctaneRender® for 3ds max® v1.50a
Karba
rogerteddy wrote:Hi,
I had a scene, where I used Pflow Particles. It was working in maxtane 1.2 but now preview window doesn´t work anymore. It takes hours to open and then it remains at sanple 1 forever, even closing the window is not possible, max crashes. When I delete the Pflow Particles everything works good.
best regards
rog
Hi Rog
May I have your scene?
[email protected]
User avatar (Default)
merid888
hi karba, the new versión take a lot memory, why ? more 500 mb, i am limited to use my gtx690
add image
merid888
hi karba, the new versión 1.50a take a lot memory, why ? more 500 mb, i am limited to use my gtx690
add image
Karba
merid888 wrote:hi karba, the new versión 1.50a take a lot memory, why ? more 500 mb, i am limited to use my gtx690
add image
1.50 takes into account render settings, like render iteration of mesh/turbo smooth and other kind of object. May be you set something too high.
Karba
add image
Could you send me your scene? I will investigate it deeper.
[email protected]
Thank you
GlobalMarketing
Hi there
I have a problem with octane render animaition minute
Normally render time 22 seconds frame of but when i was rendering sequence 20 to 130 the render time frame of 01:22 minutes
Why the time is too different octane viewport and max render frame
Can you help me how can i fix this?
Thank you.
merid888
hi karba, i been sent a mail to this address [email protected]
thank you
coilbook
Is anyone getting pure black models in 3ds max viewport when using MIX materials? thanks
Karba
merid888 wrote:hi karba, i been sent a mail to this address [email protected]
thank you
Just checked.
Both versions take the same amount of memory +/- 20Mb
Karba
GlobalMarketing wrote:Hi there
Thank you.
Do you have any geometry animation for that sequence? Did you try to switch off "update animation geometry" option?
Return to “Autodesk 3Ds Max”
