Octane 2.0 Object Motion Blur and some other features
- MaTtY631990
OctaneRender is going to blow the industry away and beyond
Hi Karba,
will it be possible to use Water Level with the displacement ?
Like this : http://www.peterguthrie.net/blog/2010/0 ... nded-metal
Thank you !
Thank you !
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
- Seekerfinder
Noooooooooooooooooooooooooo!!!!Karba wrote:relox wrote:it will have come out edges??? this is just an example----
Not true. You just have not found a way yet.Karba wrote:It will. There is no way to avoid it....
What will happen if rounded edges are applied to a displacement surface joint like this?
Seeker
Can't you just chamfer this edge and unwrap it properly to avoid this kind of edge?
Games use it this way since a long time. If you just add a cubic unwrap the seam will appear. with proper UV-Mapping it shouldn't.
PURE3D Visualisierungen
- gordonrobb
Will there be a way to set the midpoint for displacements. So that you can have negative and positive displacements?
+1 : Very important to avoid changing the average volume of models (Bump on characters clothes for example) !Will there be a way to set the midpoint for displacements. So that you can have negative and positive displacements ?
Thanks karba, if you have some example with the width a wall facing to the camera it will help alot, if its not i will wait a bit to someone makes an expample, yes i can chamfered the walls but i have it tested with other software Corona with a wall chamfered occurs the same cut edges it will display but not like if the wall was a square object,they look less.
Waa !
I just discovered this topic and i'm pretty impressed.
The truck animation is just awesome.
What scatterer did you use for vegetation?
Was the truck anim achieved with craft director, madcar,ant simulator ???
Can't wait to have all this stuffs, especialy also the hair (I just post my first Octane rendering in the galery; Hair was achieved with geometry and i'm not pretty satisfacted of the result...). link below:
http://render.otoy.com/forum/viewtopic.php?f=5&t=39332
Anyway keep doing the good job and please give us a 2.0 RC version as soon as possible !!!
Best regards.
Best regards.
