CSV Exporter
matej
This is a small utility tool to export instance transforms to a .csv file to be used inside standalone Octane. There is the other instances exporter script that needs the unofficial Lionel's exporter plugin to work properly and has some additional functionality (it exports the base particle mesh for you)
This one just creates a .csv and nothing else. You have to export the appropriate particle meshes yourself.
Select your emitter in the 3D window, choose the location where to save files, choose the up axis (Octane has Y up, which is the default selection) and hit Export transforms. Note that the button will be greyed out, if the active selected object in the scene is not a duplicator.
So, what's a "duplicator":
* An emitter that has one or more particle systems assigned. The exported .csv file will have the name of the PS. Works for hair and emitter. Only "object visualization" is supported.
* An emitter that has dupliverts / duplifaces enabled. The .csv file will have the name of the emitter object.
* Any object that has a shared mesh datablock. This means that you can Alt+D duplicate your objects, select one (any) of them and it will export the object datablock transforms for all of them that share this mesh. The .csv file will have the name of the mesh.
IMPORTANT: When you are saving your particle mesh (obj/mtl combo), it must be centred at Blender world origin, because Octane treats .csv data as absolute global positions.
It installs just like any addon. Its located in the import-export tab and shows up in the Toolbar on the left side of the 3D window.
Hope it will be useful to some of you :D
csvexporter_v101.zip
(3.46 KiB) Downloaded 947 times
cgmo.net
matej
A visual reminder how to setup instances in Octane (if anoyne forgot :D )
The scene has one emitter with two PS (one hair and one emitter type). Each PS uses a different object for visualization.
Cheers!
cgmo.net
ROUBAL
Great work. I am happy of it. Installed and works well in Blender official and Blender for Octane.
Thank you very much ! :P
matej
I've updated the top post with a new version that fixes two issues wit hair emitter (details in the other thread)
cgmo.net
ROUBAL
Thanks a lot.
Like I did last time, I have done few cosmetical tweaks (that's all I am able to do :D ) for my own usage : Changed to the render panel to have it with my other exporters and added version number to avoid confusion if reinstall is needed.
As you may have some good reasons to disable the version number, I wrote it in the label itself.
If at one moment you have to update the script again for any reason, it could be useful to make the version number appear in the GUI :
pegot
Thanks - this script works perfectly! Is there any way to have it generate a series of CSV files for each frame of a Blender animation? Then we could feed those files into the animation feature of Octane SA’s scatter node.
I tested this with a few manually generated CSV files on different frames in Blender and it works great when brought into Octane. But I have no idea how to tell Blender to automate such an export for all frames of an animation.
Win 11 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
fivebythree
Perfect! Thank you for making the plugin.
STANDALONE+STUDIO WIN11PRO | RTX3090 | XEON 4210 20 CORE | 96GBRam
christophritler
This Plugin would be perfect, but I can't get it to work properly.
Blender Version is 2.76
When I hit the export button, the plugin tells me that it was exported correctly,
but there is no .csv file in the specified folder.
What am I doing wrong? :|
regionfive
you rock! :D
Issa
I made a little change to allow animation export
#!/usr/bin/python
# -*- coding: utf-8 -*-
# ##### BEGIN GPL LICENSE BLOCK #####
#  This program is free software; you can redistribute it and/or
#  modify it under the terms of the GNU General Public License
#  as published by the Free Software Foundation; either version 3
#  of the License, or (at your option) any later version.
#  This program is distributed in the hope that it will be useful,
#  but WITHOUT ANY WARRANTY; without even the implied warranty of
#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#  GNU General Public License for more details.
#  You should have received a copy of the GNU General Public License
#  along with this program; if not, write to the Free Software Foundation,
#  Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
# ##### END GPL LICENSE BLOCK #####
bl_info = {
	"name": "CSV instance transform exporter",
	"author": "Matej Moderc, Issa",
	"version": (1,0,1),
	"blender": (2, 6, 3),
	"location": "Toolbar",
	"description": "Writes a .csv file containing instance transforms of selected duplicator object",
	"warning": "testing",
	"wiki_url": "",
	"tracker_url": "",
	"category": "Import-Export"}
from math import radians
import os
import bpy
import bpy.path as bpath
from bpy.types import Operator, Panel, PropertyGroup
from bpy.props import StringProperty, EnumProperty, PointerProperty
from mathutils import Matrix, Quaternion, Vector
VERSION = ".".join(str(v) for v in bl_info["version"])
def info(msg):
	print("INFO: %s" % msg)
def warning(msg):
	print("WARNING: %s" % msg)
def error(msg):
	print("ERROR: %s" % msg)
class CSVExportException(Exception):
	def __init__(self, msg):
		self._msg = msg
	def __str__(self):
		return repr(self._msg)
#	EXPORT FUNCTIONS   #
def writeTransform(t, fh):
	"""Writes first three matrix rows to the file handle"""
	vals = ["%.6f" % v for v in tuple(t[0]) + tuple(t[1]) + tuple(t[2])]
	fh.write(" ".join(vals) + "\n")
def exportDuplis(context, emitter, t_world, t_world_inv):
	"""Exports dupli objects (dupliverts / duplifaces) for the specified emitter"""
	info("Exporting dupli objects for '%s'" % emitter.name)
	export_dir = bpath.abspath(context.scene.csv_exporter_options.export_dir)
	emitter.dupli_list_create(context.scene)
	lst = emitter.dupli_list
	if len(lst) == 0: # if not on active layers, dupli list = empty
		return
	try:
		fh = open(export_dir + emitter.name + ".csv", "w")
		for duplicate in lst.values():
			t = duplicate.matrix.copy()
			writeTransform(t_world * t * t_world_inv, fh)
		fh.close()
	except IOError as err:
		msg = "IOError during file handling '{0}'".format(err)
		error(msg)
		raise CSVExportException(msg)
	emitter.dupli_list_clear()
def exportMeshDuplis(context, obj, users, t_world, t_world_inv):
	"""Exports the transforms of Alt+D duplicated objects"""
	csv_filename = export_dir + obj.data.name + ".csv"
	info("Saving transforms for '%s' mesh-dupli objects into file '%s' " % (obj.data.name, csv_filename))
	try:
		fh = open(csv_filename, "w")
		for o in users:
			t = o.matrix_world.copy()
		fh.close()
		error(msg)
def exportParticles(context, emitter, psys, t_world, t_world_inv):
	"""Exports the particle system transforms for the specified emitter"""
	pset = psys.settings
	infostr = "Exporting PS '%s' (%s) on emitter '%s'" % (psys.name, pset.type, emitter.name)
	particles = [p for p in psys.particles] if pset.type == 'HAIR' else [p for p in psys.particles if p.alive_state == 'ALIVE']
	if pset.render_type != "OBJECT":
		warning("Invalid PS visualization type '%s'" % pset.render_type)
		return
	if not pset.use_rotation_dupli:
		warning("'Use object rotation' should be on. Rotations wont conform to Blender veiwport")
	try:
		fh = open(export_dir + psys.name + ".csv", "w")
		for p in particles:
			#if pset.type == 'HAIR' or not p.alive_state == 'DEAD':
			rot = Quaternion.to_matrix(p.rotation).to_4x4()
			if (pset.type == "HAIR"):
				h1 = p.hair_keys[0].co
				h2 = p.hair_keys[-1].co
				loc = Matrix.Translation(h1)
				scale = Matrix.Scale((h2 - h1).length, 4)
				emitter_rot = emitter.matrix_world.decompose()[1].to_matrix().to_4x4()
				rot = emitter_rot.inverted() * rot
			else:
				loc = Matrix.Translation(p.location.copy())
				scale = Matrix.Scale(p.size, 4)
			t = loc * rot * scale
			t = emitter.matrix_world * t if pset.type == "HAIR" else t
		fh.close()
		error(msg)
#		GUI		  #
### GLOBAL OPTIONS OF THE EXPORTER ###
class CSVExporterOptions(PropertyGroup):
	export_dir = StringProperty(
		name = "",
		default = "/tmp",
		description = "Define the export path for the .csv file",
		subtype = "DIR_PATH"
	world_space = EnumProperty(
		name="World space options",
		items=(('Y Up', 'Y Up', 'Writes transforms in Octane world space'),
				('Z Up', 'Z Up', 'Writes transforms in Blender native space')),
		default='Y Up',
		#update=callback
### EXPORTER PANEL ###
class CSVExporterPanel(Panel):
	"""Exports instance transforms to a .csv file"""
	bl_space_type = "VIEW_3D"
	bl_region_type = "TOOLS"
	bl_label = "CSV Exporter" #+ VERSION
	def draw_header(self, context):
		layout = self.layout
		layout.label(text="", icon="PARTICLES")
	def draw(self, context):
		sce = context.scene
		opts = sce.csv_exporter_options
		col = layout.column()
		col.label(text="Select export path")
		col.prop(opts, "export_dir")
		col.label(text="Select up axis")
		row = layout.row()
		row.prop(opts, "world_space", expand=True)
		col = layout.column(align=True)
		col.operator("ops.csv_write_transforms", icon="RENDER_STILL")
		col.operator("ops.csv_write_animation", icon="RENDER_ANIMATION")
### WRITE TRANSFORMS BUTTON ###
class CSVWriteTransforms(Operator):
	"""Writes instance transforms to .csv file. Note that a duplicator object must be selected."""
	bl_idname = "ops.csv_write_transforms"
	bl_label = "Export transforms"
	def execute(self, context):
		info("CSV instance transforms exporter")
		sce = context.scene
		with_warnings = False
		msg = None
		t_scale = Matrix.Scale(1, 4) #TODO: check for aplicable scaling
		t_world = Matrix.Rotation(radians(-90.0), 4, 'X') * t_scale
		t_world_inv = Matrix.Rotation(radians(90.0), 4, 'X') * t_scale.inverted()
		world_space_tag = sce.csv_exporter_options.world_space
		info("Exporting in %s world space" % (world_space_tag))
		if world_space_tag == "Z Up":
			t_world = Matrix.Identity(4)
			t_world_inv = Matrix.Identity(4)
		# utility func to send warnings through Blender GUI
		def report_warning(msg):
			self.report({'WARNING'}, msg)
			nonlocal with_warnings
			with_warnings = True
		ob = context.selected_objects[0]
		if ob.is_duplicator: # and obj.is_visible(sce) and not obj.hide_render:
			info("Found duplicator '%s' of type '%s'" % (ob.name, ob.dupli_type))
			if ob.dupli_type in ('FACES', 'VERTS'):
				exportDuplis(context, ob, t_world, t_world_inv)
			elif ob.dupli_type == 'NONE' and len(ob.particle_systems) > 0:
				# even if NONE for dupliverts, its possible PS
				if len(ob.particle_systems) > 0:
					for ps in ob.particle_systems:
						pset = ps.settings
						if pset.render_type == "OBJECT":
							exportParticles(context, ob, ps, t_world, t_world_inv)
						else:
							report_warning("Unsupported PS vizualisation type '%s'" % pset.render_type)
				else:
					report_warning("Object '%s' has no particle systems attached" % ob.name)
			else:
				report_warning("Unsupported duplicator type '%s'" % ob.dupli_type)
		# if not duplicator, possible dupliverts
		elif ob.type == "MESH" and ob.data.users > 1:
			# find all users of the mesh of this object, aka. duplicates
		#	meshes = bpy.data.meshes
			me = ob.data
			users = [o for o in bpy.data.objects if o.type == "MESH" and o.data == me]
			info("Found %i users for dupli-mesh '%s'" % (len(users), me.name))
			exportMeshDuplis(context, ob, users, t_world, t_world_inv)
		else:
			report_warning("The selected object '%s' is not an instance emitter or mesh-dupli" % ob.name)
		if with_warnings:
			msg = "Script ended with warnings, look into console"
		else:
			msg = "Export complete. CSV file(s) written in '%s'" % (sce.csv_exporter_options.export_dir)
			info(msg)
			self.report({'INFO'}, msg)
		return {"FINISHED"}
	# button is active only when selected object is a duplicator
	@classmethod
	def poll(self, context):
		obs = context.selected_objects
		if len(obs) < 1:
			return False
		ob = obs[0]
		return ob.is_duplicator or (ob.type == "MESH" and ob.data.users > 1)
### WRITE ANIMATION BUTTON ###
class CSVWriteAnimation(Operator):
	bl_idname = "ops.csv_write_animation"
	bl_label = "Export animation"
	@classmethod
		if len(obs) < 1:
			return False
		ob = obs[0]
		sce = context.scene
		###Export !
		curFilePath = sce.csv_exporter_options.export_dir
		if not os.path.isdir(curFilePath):
			curFilePath = os.path.split(curFilePath)[0]+"\\"
		RANGE = range(sce.frame_start, sce.frame_end+1)
		for frame in RANGE:
			#sce.frame_current =
			bpy.context.scene.frame_set(frame)
			bpy.data.particles.update()
			sce.update()
			sce.csv_exporter_options.export_dir = curFilePath + ("%06d" % (sce.frame_current,)) + "_"
			bpy.ops.ops.csv_write_transforms()
		return {"FINISHED"}
def register():
	bpy.utils.register_class(CSVWriteTransforms)
	bpy.utils.register_class(CSVWriteAnimation)
	bpy.utils.register_class(CSVExporterPanel)
	bpy.utils.register_class(CSVExporterOptions)
	#bpy.utils.register_module(__name__)
	bpy.types.Scene.csv_exporter_options = PointerProperty(type=CSVExporterOptions)
def unregister():
	bpy.utils.unregister_class(CSVWriteTransforms)
	bpy.utils.unregister_class(CSVWriteAnimation)
	bpy.utils.unregister_class(CSVExporterPanel)
	bpy.utils.unregister_class(CSVExporterOptions)
	#bpy.utils.unregister_module(__name__)
	del bpy.types.Scene.csv_exporter_options
if __name__=="__main__":
	register()
Return to “Blender”
