OctaneRender® for Poser (Mac OS X) 1.50 [UNSUPPORTED]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Poser, build 1.50 (STABLE RELEASE). This version is compiled against Octane 1.50, so see the requirements for that build regarding compatibility with your video card.
This version runs on Poser9/PoserPro2012 and Poser10/PoserPro2014, on Macintosh OS X Lion & Mountain Lion. It may run on Snow Leopard.
Installation
Install the supplied pkg. This is setup for Poser Pro 2014, so you will need to install into the Poser Pro 2012/Poser 9 Runtime if you are on those version.
- Operating System (ie. Mac OS X Mountain Lion)
- Amount of RAM
- Nvidia driver version
- Poser version (Poser -> Help -> About Poser) - list the build number (eg. 9.0.3.23027)
- OctaneRender for Plugin version (ie. X.XXa)
- Also have ready a copy of the octaneplugin.log and cuda.log file from your Poser temp direction (Poser -> Edit -> General Preferences -> Misc tab to find the temp directory)
Change Log from release 1.20a
- Pls see Window version thread for change details
Differences between the MAC and WINDOWS version
- You cannot rightclick the Progressive save button to open the progressive save folder
- Uses the standard Mac color picker rather than an "advanced" color picker
If you have questions....
- Read the latest up-to-date on-line manual
- Read the PDF manual (supplied with the ZIP installer)
- Read the FAQ
- Watch the Features Video
- Read the Features Blog Posting
- Watch the Introductory Tutorial
- Check the Facebook Page
- Post your question on this forum thread
Troubleshooting
N/A
Limitations
Refer to the on-line manual
Download the plugin HERE
Victor2112
I installed the OctaneRender_for_Poser_1_50_0_22_MacOSX.pkg and started up Poser 10. However, I do not see any way to utilize Octane. I looked in the Render menu but do not see anything. I checked the Scripts menu but could not see anything for Octane.
Am I missing something? I saw one of the Feature Videos and it showed there being a menu option under Scripts with the Octane selection.
* Mac OS X Mavericks
* 16 GB Ram
* GTX780M, 4GB Ram
* CUDA Driver: 5.50
* Poser 10.0.3.26066
* Octane Plugin version: 1.50.0.22
Hi - can you pls post your octaneplugin.log file?
Victor2112
I do not seem to have an octaneplugin.log file. I did a search on my computer for the file but found nothing. I ran the Octane***MacOSX.pkg again and it said the install was successful.
I do have a Users\<myname>\Library\OctaneRender folder but I do not see any log files. Would you be able to to tell me where I could find this file?
And thank you for the help. I do look forward to using this plugin.
Hi - there are instruction above for finding the log file.
Victor2112
Sorry about that. I should have read ALL the instructions before posting. :P
I went to the listed directory and I do not see any octaneplugin.log or cuds.log file. All I have there is a Poser.log file. Within that Poser.log file I did see some octane_2014-04-02-160427_iMac_wakeups_resouce.spin entry....(It was under the "DiagnosticReport" section. I hope this helps.
Date/Time: 2014-04-02 16:03:17 -0400
OS Version: 10.9.2 (Build 13C64)
Architecture: x86_64
Report Version: 18
Command: OctaneRender
Path: /Applications/OctaneRender 1.50.app/Contents/MacOS/octane
Version: 1.50 (1.50)
Parent: launchd [239]
PID: 21115
Event: wakeups (microstackshots only)
Wakeups: 652 wakeups per second for 70 seconds
Duration: 70.00s
Steps: 69
Hardware model: iMac14,2
Active cpus: 8
Fan speed: 1200 rpm
Powerstats for: octane [21115]
Start time: 2014-04-02 16:03:23 -0400
End time: 2014-04-02 16:04:26 -0400
Parent: launchd
Microstackshots: 33 samples (47%)
Primary state: 17 samples Non-Frontmost App, Non-Background Priority, Kernel mode
User Activity: 0 samples Idle, 33 samples Active
Power Source: 0 samples on Battery, 33 samples on AC
12 _dispatch_mgr_thread + 52 (libdispatch.dylib) [0x7fff8a743152]
8 kevent64 + 10 (libsystem_kernel.dylib) [0x7fff8a778662]
2 <Frontmost App>
3 _dispatch_mgr_invoke + 127 (libdispatch.dylib) [0x7fff8a7433cd]
3 _dispatch_timers_program + 616 (libdispatch.dylib) [0x7fff8a7470c6]
3 kevent64 + 10 (libsystem_kernel.dylib) [0x7fff8a778662]
1 _dispatch_mgr_invoke + 93 (libdispatch.dylib) [0x7fff8a7433ab]
1 _dispatch_timers_run + 109 (libdispatch.dylib) [0x7fff8a7489b8]
1 _dispatch_get_nanoseconds + 19 (libdispatch.dylib) [0x7fff8a747112]
1 __gettimeofday + 10 (libsystem_kernel.dylib) [0x7fff8a7771cb]
9 mRandom::Seed(unsigned int) + 1502 (octane) [0x96794]
8 boost::system::system_error::~system_error() + 2080153 (octane) [0x29c2b9]
8 boost::system::system_error::~system_error() + 876639 (octane) [0x17657f]
8 -[NSApplication run] + 553 (AppKit) [0x7fff8c305b2c]
8 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 122 (AppKit) [0x7fff8c311a2b]
8 _DPSNextEvent + 2170 (AppKit) [0x7fff8c3126be]
8 _NSHandleCarbonMenuEvent + 284 (AppKit) [0x7fff8c4b373c]
8 _HandleMenuSelection2 + 446 (HIToolbox) [0x7fff88365cc1]
7 MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 718 (HIToolbox) [0x7fff88366095]
7 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 94 (HIToolbox) [0x7fff8835e0bf]
7 SendMenuItemSelectedEvent + 178 (HIToolbox) [0x7fff8835e1e0]
7 SendMenuCommandWithContextAndModifiers + 59 (HIToolbox) [0x7fff8835e238]
7 SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 420 (HIToolbox) [0x7fff8832b640]
7 SendEventToEventTarget + 40 (HIToolbox) [0x7fff882f5880]
7 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 385 (HIToolbox) [0x7fff882e1787]
7 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 892 (HIToolbox) [0x7fff882e21d4]
7 NSSLMMenuEventHandler + 716 (AppKit) [0x7fff8c5410d6]
7 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 104 (AppKit) [0x7fff8c59a309]
7 -[NSMenu _internalPerformActionForItemAtIndex:] + 35 (AppKit) [0x7fff8c59a48d]
7 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 117 (AppKit) [0x7fff8c54afe4]
7 -[NSMenuItem _corePerformAction] + 394 (AppKit) [0x7fff8c54b2a8]
7 -[NSApplication sendAction:to:from:] + 327 (AppKit) [0x7fff8c530340]
7 boost::system::system_error::~system_error() + 1641313 (octane) [0x231081]
7 boost::system::system_error::~system_error() + 4250439 (octane) [0x4ae067]
7 boost::system::system_error::~system_error() + 4465079 (octane) [0x4e26d7]
7 boost::system::system_error::~system_error() + 2949839 (octane) [0x3707ef]
7 boost::system::system_error::~system_error() + 2114605 (octane) [0x2a494d]
7 boost::system::system_error::~system_error() + 1523649 (octane) [0x2144e1]
6 boost::system::system_error::~system_error() + 874959 (octane) [0x175eef]
6 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 122 (AppKit) [0x7fff8c311a2b]
6 _DPSNextEvent + 1434 (AppKit) [0x7fff8c3123de]
6 _BlockUntilNextEventMatchingListInModeWithFilter + 65 (HIToolbox) [0x7fff883085bc]
4 ReceiveNextEventCommon + 479 (HIToolbox) [0x7fff883087b7]
4 RunCurrentEventLoopInMode + 226 (HIToolbox) [0x7fff88308a0d]
4 CFRunLoopRunSpecific + 309 (CoreFoundation) [0x7fff81d310b5]
2 __CFRunLoopRun + 1161 (CoreFoundation) [0x7fff81d31779]
2 __CFRunLoopServiceMachPort + 181 (CoreFoundation) [0x7fff81d32155]
2 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8a773a1a]
1 __CFRunLoopRun + 1310 (CoreFoundation) [0x7fff81d3180e]
1 _kernelrpc_mach_port_extract_member_trap + 10 (libsystem_kernel.dylib) [0x7fff8a7739c6]
1 __CFRunLoopRun + 494 (CoreFoundation) [0x7fff81d314de]
1 _dispatch_barrier_async_f_slow + 24 (libdispatch.dylib) [0x7fff8a742667]
1 _dispatch_continuation_alloc_from_heap + 49 (libdispatch.dylib) [0x7fff8a7426df]
1 calloc + 49 (libsystem_malloc.dylib) [0x7fff814472ca]
1 malloc_zone_calloc + 79 (libsystem_malloc.dylib) [0x7fff81446b61]
1 nano_calloc + 76 (libsystem_malloc.dylib) [0x7fff8144871a]
1 OSAtomicDequeue + 17 (libsystem_platform.dylib) [0x7fff81ea9cd1]
1 <Frontmost App, User mode>
2 ReceiveNextEventCommon + 145 (HIToolbox) [0x7fff88308669]
2 GetCurrentEventQueue + 23 (HIToolbox) [0x7fff8830886d]
2 MPTaskIsPreemptive + 22 (CarbonCore) [0x7fff87d9a927]
1 ThreadIsCooperative + 38 (CarbonCore) [0x7fff87d9a957]
1 TSLockMutex + 48 (CarbonCore) [0x7fff87d99aa0]
1 <User mode>
1 ThreadIsCooperative + 17 (CarbonCore) [0x7fff87d9a942]
1 <User mode>
1 objc_msgSend_fixedup + 4 (libobjc.A.dylib) [0x7fff8243a1c8]
1 <User mode>
1 MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 441 (HIToolbox) [0x7fff88365f80]
1 TrackMenuCommon(MenuSelectData&, unsigned char*) + 1545 (HIToolbox) [0x7fff88353c61]
1 IsUserStillTracking(MenuSelectData*, unsigned char*) + 186 (HIToolbox) [0x7fff8835405a]
1 AcquireNextEventInMode + 51 (HIToolbox) [0x7fff883565cd]
1 ReceiveNextEventCommon + 479 (HIToolbox) [0x7fff883087b7]
1 RunCurrentEventLoopInMode + 226 (HIToolbox) [0x7fff88308a0d]
1 CFRunLoopRunSpecific + 309 (CoreFoundation) [0x7fff81d310b5]
1 __CFRunLoopRun + 2002 (CoreFoundation) [0x7fff81d31ac2]
1 boost::system::system_error::~system_error() + 2080121 (octane) [0x29c299]
1 boost::system::system_error::~system_error() + 2079305 (octane) [0x29bf69]
1 mRandom::Seed(unsigned int) + 2690 (octane) [0x96c38]
1 boost::system::system_error::~system_error() + 4063613 (octane) [0x48069d]
1 boost::system::system_error::~system_error() + 4243487 (octane) [0x4ac53f]
1 boost::system::system_error::~system_error() + 4234987 (octane) [0x4aa40b]
1 boost::system::system_error::~system_error() + 1396387 (octane) [0x1f53c3]
1 -[NSButtonCell performClick:] + 558 (AppKit) [0x7fff8c57c73d]
1 -[NSCell _sendActionFrom:] + 128 (AppKit) [0x7fff8c57cced]
1 -[NSControl sendAction:to:] + 86 (AppKit) [0x7fff8c5301be]
1 -[NSApplication sendAction:to:from:] + 327 (AppKit) [0x7fff8c530340]
1 boost::system::system_error::~system_error() + 127143 (octane) [0xbf5c7]
1 -[NSWindow zoom:] + 800 (AppKit) [0x7fff8ca894b2]
1 -[NSWindow setFrame:display:animate:] + 1067 (AppKit) [0x7fff8c43264e]
1 -[NSMoveHelper _resizeWindow:toFrame:display:] + 420 (AppKit) [0x7fff8ca95cf3]
1 -[NSMoveHelper _doAnimation] + 1521 (AppKit) [0x7fff8c668f3b]
1 __CFRunLoopRun + 1525 (CoreFoundation) [0x7fff81d318e5]
1 __CFRunLoopDoTimers + 298 (CoreFoundation) [0x7fff81de75aa]
1 __CFRunLoopDoTimer + 1151 (CoreFoundation) [0x7fff81d7609f]
1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20 (CoreFoundation) [0x7fff81d76564]
1 __28-[NSMoveHelper _doAnimation]_block_invoke + 1157 (AppKit) [0x7fff8c669c71]
1 -[NSWindow _setFrameCommon:display:stashSize:] + 2662 (AppKit) [0x7fff8c433391]
1 -[NSThemeFrame handleSetFrameCommonRedisplay] + 251 (AppKit) [0x7fff8c448d01]
1 -[NSView displayIfNeeded] + 1680 (AppKit) [0x7fff8c44942a]
1 -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 2828 (AppKit) [0x7fff8c469fbf]
1 -[NSThemeFrame _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 314 (AppKit) [0x7fff8c46cfd1]
1 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 3199 (AppKit) [0x7fff8c46e15c]
1 -[NSView _drawRect:clip:] + 3846 (AppKit) [0x7fff8c4711d1]
1 -[NSThemeFrame drawRect:] + 302 (AppKit) [0x7fff8c55233a]
1 -[NSFrameView drawRect:] + 1065 (AppKit) [0x7fff8c55278a]
1 -[NSThemeFrame drawFrame:] + 153 (AppKit) [0x7fff8c4769fa]
1 -[NSThemeFrame _drawTitleStringInClip:] + 186 (AppKit) [0x7fff8c476f38]
1 -[NSTitledFrame _drawTitleStringIn:withColor:] + 466 (AppKit) [0x7fff8c477127]
1 _NSDrawTextCell + 6134 (AppKit) [0x7fff8c478926]
1 -[NSAttributedString enumerateAttribute:inRange:options:usingBlock:] + 193 (Foundation) [0x7fff83088012]
1 -[NSAttributeDictionary objectForKey:] + 93 (AppKit) [0x7fff8c35b2e7]
6 __pthread_set_self + 16 (libsystem_pthread.dylib) [0x7fff8a14cfac]
3 <Frontmost App>
5 start_wqthread + 13 (libsystem_pthread.dylib) [0x7fff8a14cfb9]
5 _pthread_wqthread + 314 (libsystem_pthread.dylib) [0x7fff8a149ef8]
5 _dispatch_worker_thread2 + 40 (libdispatch.dylib) [0x7fff8a744193]
5 _dispatch_root_queue_drain + 75 (libdispatch.dylib) [0x7fff8a742fa3]
1 _dispatch_dispose + 55 (libdispatch.dylib) [0x7fff8a741dd7]
1 object_dispose + 22 (libobjc.A.dylib) [0x7fff8243c384]
1 objc_destructInstance + 126 (libobjc.A.dylib) [0x7fff8243c020]
1 objc_clear_deallocating + 96 (libobjc.A.dylib) [0x7fff8243c096]
1 objc::DenseMapBase<objc::DenseMap<objc_object*, unsigned long, true, objc::DenseMapInfo<objc_object*> >, objc_object*, unsigned long, objc::DenseMapInfo<objc_object*>, true>::find(objc_object* const&) + 35 (libobjc.A.dylib) [0x7fff8245261b]
1 bool objc::DenseMapBase<objc::DenseMap<objc_object*, unsigned long, true, objc::DenseMapInfo<objc_object*> >, objc_object*, unsigned long, objc::DenseMapInfo<objc_object*>, true>::LookupBucketFor<objc_object*>(objc_object* const&, std::__1::pair<objc_object*, unsigned long> const*&) const + 73 (libobjc.A.dylib) [0x7fff8245280d]
1 _dispatch_queue_push_list_slow2 + 30 (libdispatch.dylib) [0x7fff8a7427a8]
1 _dispatch_wakeup + 28 (libdispatch.dylib) [0x7fff8a7421be]
1 _dispatch_mgr_wakeup + 34 (libdispatch.dylib) [0x7fff8a7428fd]
1 kevent64 + 10 (libsystem_kernel.dylib) [0x7fff8a778662]
1 <Frontmost App>
1 _dispatch_dispose + 35 (libdispatch.dylib) [0x7fff8a741dc3]
1 _dispatch_source_dispose + 18 (libdispatch.dylib) [0x7fff8a74810d]
1 free + 64 (libsystem_malloc.dylib) [0x7fff81446f24]
1 nano_size + 78 (libsystem_malloc.dylib) [0x7fff81447ff5]
1 <User mode>
1 _dispatch_source_invoke + 297 (libdispatch.dylib) [0x7fff8a74382d]
1 _dispatch_source_cancel_callout + 184 (libdispatch.dylib) [0x7fff8a7480ac]
1 _dispatch_client_callout + 8 (libdispatch.dylib) [0x7fff8a7412ad]
1 __CFRunLoopTimeoutCancel + 26 (CoreFoundation) [0x7fff81d80f9a]
1 -[OS_dispatch_source _xref_dispose] + 5 (libdispatch.dylib) [0x7fff8a7480be]
1 <User mode>
1 _dispatch_source_invoke + 413 (libdispatch.dylib) [0x7fff8a7438a1]
1 CFRunLoopWakeUp + 75 (CoreFoundation) [0x7fff81d1e45b]
1 OSAtomicCompareAndSwap64Barrier$VARIANT$up + 16 (libsystem_platform.dylib) [0x7fff81ea9bcc]
1 <User mode>
1 thread_start + 13 (libsystem_pthread.dylib) [0x7fff8a14cfc9]
1 _pthread_start + 137 (libsystem_pthread.dylib) [0x7fff8a14872a]
1 _pthread_body + 138 (libsystem_pthread.dylib) [0x7fff8a148899]
1 _NSEventThread + 144 (AppKit) [0x7fff8c4b216e]
1 __CFRunLoopRun + 1161 (CoreFoundation) [0x7fff81d31779]
1 __CFRunLoopServiceMachPort + 181 (CoreFoundation) [0x7fff81d32155]
1 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8a773a1a]
Binary Images:
0 - 0x153bfd7 com.otoy.octanerender 1.50 (1.50) <6CADF221-579F-048F-1B55-7614A8B1446C> /Applications/OctaneRender 1.50.app/Contents/MacOS/octane
0x7fff81436000 - 0x7fff81451ff7 libsystem_malloc.dylib (23.10.1) <A695B4E4-38E9-332E-A772-29D31E3F1385> /usr/lib/system/libsystem_malloc.dylib
0x7fff81cc1000 - 0x7fff81ea6fff com.apple.CoreFoundation 6.9 (855.14) <617B8A7B-FAB2-3271-A09B-C542E351C532> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff81ea7000 - 0x7fff81eadff7 libsystem_platform.dylib (24.90.1) <3C3D3DA8-32B9-3243-98EC-D89B9A1670B3> /usr/lib/system/libsystem_platform.dylib
0x7fff82435000 - 0x7fff825e2f27 libobjc.A.dylib (551.1) <AD7FD984-271E-30F4-A361-6B20319EC73B> /usr/lib/libobjc.A.dylib
0x7fff83029000 - 0x7fff83327fff com.apple.Foundation 6.9 (1056.13) <2EE9AB07-3EA0-37D3-B407-4A520F2CB497> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff87d95000 - 0x7fff8807ffff com.apple.CoreServices.CarbonCore 1077.17 (1077.17) <3A2E92FD-DEE2-3D45-9619-11500801A61C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff882da000 - 0x7fff88584ff5 com.apple.HIToolbox 2.1 <DF5635DD-C255-3A8E-8B49-F6D2FB61FF95> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff8a147000 - 0x7fff8a14eff7 libsystem_pthread.dylib (53.1.4) <AB498556-B555-310E-9041-F67EC9E00E2C> /usr/lib/system/libsystem_pthread.dylib
0x7fff8a740000 - 0x7fff8a75afff libdispatch.dylib (339.90.1) <F3CBFE1B-FCE8-3F33-A53D-9092AB382DBB> /usr/lib/system/libdispatch.dylib
0x7fff8a762000 - 0x7fff8a77eff7 libsystem_kernel.dylib (2422.90.20) <20E00C54-9222-359F-BD98-CB79ABED769A> /usr/lib/system/libsystem_kernel.dylib
0x7fff8c2ee000 - 0x7fff8ce64fff com.apple.AppKit 6.9 (1265.19) <12647F2F-3FE2-3D77-B3F0-33EFAFF2CEA7> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
Powerstats for: com.apple.WebKit
Start time: 2014-04-02 16:03:38 -0400
End time: 2014-04-02 16:04:24 -0400
Microstackshots: 8 samples (11%)
Primary state: 7 samples Non-Frontmost App, Non-Background Priority, User mode
User Activity: 0 samples Idle, 8 samples Active
Power Source: 0 samples on Battery, 8 samples on AC
4 start + 1 (libdyld.dylib) [0x7fff8485d5fd]
4 ??? (com.apple.WebKit.WebContent + 2976) [0x1091f0ba0]
4 xpc_main + 399 (libxpc.dylib) [0x7fff8a451bde]
4 _xpc_main + 385 (XPCService) [0x7fff886afc0f]
4 NSApplicationMain + 940 (AppKit) [0x7fff8c2f0913]
4 -[NSApplication run] + 553 (AppKit) [0x7fff8c305b2c]
4 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 122 (AppKit) [0x7fff8c311a2b]
4 _DPSNextEvent + 1434 (AppKit) [0x7fff8c3123de]
4 _BlockUntilNextEventMatchingListInModeWithFilter + 65 (HIToolbox) [0x7fff883085bc]
2 __CFRunLoopRun + 995 (CoreFoundation) [0x7fff81d316d3]
2 __CFRunLoopDoObservers + 391 (CoreFoundation) [0x7fff81d3fe57]
2 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23 (CoreFoundation) [0x7fff81d3fee7]
2 CA::Transaction::observer_callback(__CFRunLoopObserver*, unsigned long, void*) + 71 (QuartzCore) [0x7fff8a172761]
2 CA::Transaction::commit() + 388 (QuartzCore) [0x7fff8a161fd6]
2 CA::Context::commit_transaction(CA::Transaction*) + 236 (QuartzCore) [0x7fff8a16233c]
2 CA::Layer::layout_and_display_if_needed(CA::Transaction*) + 35 (QuartzCore) [0x7fff8a1628b1]
2 CA::Layer::display_if_needed(CA::Transaction*) + 590 (QuartzCore) [0x7fff8a163162]
2 CA::Layer::display_() + 1539 (QuartzCore) [0x7fff8a163a2b]
2 x_blame_allocations + 84 (QuartzCore) [0x7fff8a163f1c]
2 ___ZN2CA5Layer8display_Ev_block_invoke + 59 (QuartzCore) [0x7fff8a163f60]
2 CABackingStoreUpdate_ + 3848 (QuartzCore) [0x7fff8a164e6e]
2 -[WebTileLayer drawInContext:] + 34 (WebCore) [0x7fff8dd89dc2]
2 WebCore::TileController::drawLayer(WebTileLayer*, CGContext*) + 169 (WebCore) [0x7fff8ddc0349]
2 drawLayerContents(CGContext*, CALayer*, WebCore::PlatformCALayer*) + 950 (WebCore) [0x7fff8ddc0726]
2 WebCore::GraphicsLayer::paintGraphicsLayerContents(WebCore::GraphicsContext&, WebCore::IntRect const&) + 144 (WebCore) [0x7fff8ddc0ee0]
2 WebCore::RenderLayerBacking::paintContents(WebCore::GraphicsLayer const*, WebCore::GraphicsContext&, unsigned int, WebCore::IntRect const&) + 371 (WebCore) [0x7fff8ddc1063]
2 WebCore::RenderLayerBacking::paintIntoLayer(WebCore::GraphicsLayer const*, WebCore::GraphicsContext*, WebCore::IntRect const&, unsigned int, unsigned int) + 312 (WebCore) [0x7fff8ddc1258]
2 WebCore::RenderLayer::paintLayerContents(WebCore::GraphicsContext*, WebCore::RenderLayer::LayerPaintingInfo const&, unsigned int) + 2178 (WebCore) [0x7fff8dd81ea2]
2 WebCore::RenderLayer::paintList(WTF::Vector<WebCore::RenderLayer*, 0ul, WTF::CrashOnOverflow>*, WebCore::GraphicsContext*, WebCore::RenderLayer::LayerPaintingInfo const&, unsigned int) + 150 (WebCore) [0x7fff8dd84096]
2 WebCore::RenderLayer::paintLayer(WebCore::GraphicsContext*, WebCore::RenderLayer::LayerPaintingInfo const&, unsigned int) + 796 (WebCore) [0x7fff8dd8137c]
1 WebCore::RenderLayer::paintLayer(WebCore::GraphicsContext*, WebCore::RenderLayer::LayerPaintingInfo const&, unsigned int) + 796 (WebCore) [0x7fff8dd8137c]
1 WebCore::RenderLayer::paintLayerContents(WebCore::GraphicsContext*, WebCore::RenderLayer::LayerPaintingInfo const&, unsigned int) + 2057 (WebCore) [0x7fff8dd81e29]
1 WebCore::RenderLayer::paintForegroundForFragments(WTF::Vector<WebCore::LayerFragment, 1ul, WTF::CrashOnOverflow> const&, WebCore::GraphicsContext*, WebCore::GraphicsContext*, WebCore::LayoutRect const&, bool, WebCore::RenderLayer::LayerPaintingInfo const&, unsigned int, WebCore::RenderObject*, bool, bool) + 285 (WebCore) [0x7fff8dd841fd]
1 WebCore::RenderLayer::paintForegroundForFragmentsWithPhase(WebCore::PaintPhase, WTF::Vector<WebCore::LayerFragment, 1ul, WTF::CrashOnOverflow> const&, WebCore::GraphicsContext*, WebCore::RenderLayer::LayerPaintingInfo const&, unsigned int, WebCore::RenderObject*) + 424 (WebCore) [0x7fff8dd84488]
1 WebCore::RenderBlock::paint(WebCore::PaintInfo&, WebCore::LayoutPoint const&) + 268 (WebCore) [0x7fff8dd8615c]
1 WebCore::RenderBlock::paintObject(WebCore::PaintInfo&, WebCore::LayoutPoint const&) + 259 (WebCore) [0x7fff8dd83a83]
1 WebCore::RenderBlock::paintContents(WebCore::PaintInfo&, WebCore::LayoutPoint const&) + 228 (WebCore) [0x7fff8dd845f4]
1 WebCore::RenderBlock::paintChildren(WebCore::PaintInfo&, WebCore::LayoutPoint const&, WebCore::PaintInfo&, bool) + 88 (WebCore) [0x7fff8dd84658]
1 WebCore::RenderBlock::paintChild(WebCore::RenderBox*, WebCore::PaintInfo&, WebCore::LayoutPoint const&, WebCore::PaintInfo&, bool) + 240 (WebCore) [0x7fff8dd84770]
1 WebCore::RenderBlock::paintObject(WebCore::PaintInfo&, WebCore::LayoutPoint const&) + 76 (WebCore) [0x7fff8dd839cc]
1 WebCore::RenderBox::paintBoxDecorations(WebCore::PaintInfo&, WebCore::LayoutPoint const&) + 743 (WebCore) [0x7fff8dd86617]
1 WebCore::RenderBoxModelObject::paintBorder(WebCore::PaintInfo const&, WebCore::LayoutRect const&, WebCore::RenderStyle const*, WebCore::BackgroundBleedAvoidance, bool, bool) + 1670 (WebCore) [0x7fff8de089c6]
1 WebCore::GraphicsContext::getCTM(WebCore::GraphicsContext::IncludeDeviceScale) const + 67 (WebCore) [0x7fff8dc87d23]
1 CGContextGetCTM + 31 (CoreGraphics) [0x7fff85c4100f]
1 WebCore::RenderLayer::paintLayer(WebCore::GraphicsContext*, WebCore::RenderLayer::LayerPaintingInfo const&, unsigned int) + 389 (WebCore) [0x7fff8dd811e5]
1 __CFRunLoopRun + 831 (CoreFoundation) [0x7fff81d3162f]
1 __CFRunLoopDoSources0 + 242 (CoreFoundation) [0x7fff81d31ea2]
1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17 (CoreFoundation) [0x7fff81d40731]
1 WebCore::RunLoop::performWork(void*) + 34 (WebCore) [0x7fff8dc8f222]
1 WebCore::RunLoop::performWork() + 270 (WebCore) [0x7fff8dc8f34e]
1 CoreIPC::Connection::dispatchOneMessage() + 106 (WebKit2) [0x7fff8cee27e2]
1 CoreIPC::Connection::dispatchMessage(WTF::PassOwnPtr<CoreIPC::MessageDecoder>) + 101 (WebKit2) [0x7fff8cee28b9]
1 WebKit::WebProcess::didReceiveMessage(CoreIPC::Connection*, CoreIPC::MessageDecoder&) + 28 (WebKit2) [0x7fff8cee2950]
1 CoreIPC::MessageReceiverMap::dispatchMessage(CoreIPC::Connection*, CoreIPC::MessageDecoder&) + 125 (WebKit2) [0x7fff8cee2a6b]
1 WebKit::WebPage::didReceiveWebPageMessage(CoreIPC::Connection*, CoreIPC::MessageDecoder&) + 1273 (WebKit2) [0x7fff8cef8e2d]
1 void CoreIPC::handleMessage<Messages::WebPage::KeyEvent, WebKit::WebPage, void (WebKit::WebPage::*)(WebKit::WebKeyboardEvent const&)>(CoreIPC::MessageDecoder&, WebKit::WebPage*, void (WebKit::WebPage::*)(WebKit::WebKeyboardEvent const&)) + 107 (WebKit2) [0x7fff8cf618a7]
1 WebKit::WebPage::keyEvent(WebKit::WebKeyboardEvent const&) + 42 (WebKit2) [0x7fff8cf619f2]
1 WebKit::handleKeyEvent(WebKit::WebKeyboardEvent const&, WebCore::Page*) + 179 (WebKit2) [0x7fff8cf61aec]
1 WebCore::EventHandler::keyEvent(WebCore::PlatformKeyboardEvent const&) + 321 (WebCore) [0x7fff8e066cd1]
1 WebCore::Node::dispatchKeyEvent(WebCore::PlatformKeyboardEvent const&) + 108 (WebCore) [0x7fff8e07356c]
1 WebCore::EventDispatcher::dispatchEvent(WebCore::Node*, WTF::PassRefPtr<WebCore::EventDispatchMediator>) + 140 (WebCore) [0x7fff8dcc655c]
1 WebCore::KeyboardEventDispatchMediator::dispatchEvent(WebCore::EventDispatcher*) const + 14 (WebCore) [0x7fff8e07366e]
1 WebCore::EventDispatchMediator::dispatchEvent(WebCore::EventDispatcher*) const + 12 (WebCore) [0x7fff8dcc71dc]
1 WebCore::EventDispatcher::dispatch() + 774 (WebCore) [0x7fff8dcc74e6]
1 WebCore::EventContext::handleLocalEvents(WebCore::Event*) const + 87 (WebCore) [0x7fff8dcc7ba7]
1 WebCore::EventTarget::fireEventListeners(WebCore::Event*) + 359 (WebCore) [0x7fff8dcc7997]
1 WebCore::EventTarget::fireEventListeners(WebCore::Event*, WebCore::EventTargetData*, WTF::Vector<WebCore::RegisteredEventListener, 1ul, WTF::CrashOnOverflow>&) + 633 (WebCore) [0x7fff8de85cc9]
1 WebCore::JSEventListener::handleEvent(WebCore::ScriptExecutionContext*, WebCore::Event*) + 892 (WebCore) [0x7fff8de8611c]
1 WebCore::JSMainThreadExecState::call(JSC::ExecState*, JSC::JSValue, JSC::CallType, JSC::CallData const&, JSC::JSValue, JSC::ArgList const&) + 154 (WebCore) [0x7fff8de893ca]
1 JSC::call(JSC::ExecState*, JSC::JSValue, JSC::CallType, JSC::CallData const&, JSC::JSValue, JSC::ArgList const&) + 69 (JavaScriptCore) [0x7fff88813ee5]
1 JSC::Interpreter::executeCall(JSC::ExecState*, JSC::JSObject*, JSC::CallType, JSC::CallData const&, JSC::JSValue, JSC::ArgList const&) + 595 (JavaScriptCore) [0x7fff88814143]
1 ??? [0x27a24e20ea76]
1 cti_op_resolve_with_this + 35 (JavaScriptCore) [0x7fff888db813]
1 JSC::JSScope::resolveWithThis(JSC::ExecState*, JSC::Identifier const&, JSC::Register*, WTF::Vector<JSC::ResolveOperation, 0ul, WTF::CrashOnOverflow>*) + 194 (JavaScriptCore) [0x7fff88871762]
1 JSC::JSObject* JSC::JSScope::resolveContainingScopeInternal<(JSC::JSScope::LookupMode)1, (JSC::JSScope::ReturnValues)5>(JSC::ExecState*, JSC::Identifier const&, JSC::PropertySlot&, WTF::Vector<JSC::ResolveOperation, 0ul, WTF::CrashOnOverflow>*, JSC::PutToBaseOperation*, bool) + 358 (JavaScriptCore) [0x7fff8898e896]
1 WebCore::JSHTMLFormElement::getOwnPropertySlot(JSC::JSCell*, JSC::ExecState*, JSC::PropertyName, JSC::PropertySlot&) + 368 (WebCore) [0x7fff8de46a40]
1 __CFRunLoopRun + 1636 (CoreFoundation) [0x7fff81d31954]
1 __CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE__ + 9 (CoreFoundation) [0x7fff81d76679]
1 _dispatch_main_queue_callback_4CF + 333 (libdispatch.dylib) [0x7fff8a748f03]
1 _dispatch_call_block_and_release + 12 (libdispatch.dylib) [0x7fff8a7441d7]
1 ___ZN21CGSDatagramReadStream24dispatch_datagrams_asyncEP16dispatch_queue_sPS__block_invoke + 18 (CoreGraphics) [0x7fff85cb77ec]
1 CGSDatagramReadStream::dispatch_datagrams() + 50 (CoreGraphics) [0x7fff85c56afc]
1 CGSDatagramReadStream::dispatch_next_datagram() + 42 (CoreGraphics) [0x7fff85c56b36]
1 CGSDatagramReadStream::dispatch_next_main_queue_datagram() + 287 (CoreGraphics) [0x7fff85c57941]
1 (anonymous namespace)::notify_datagram_handler(unsigned int, CGSDatagramType, void*, unsigned long, void*) + 72 (CoreGraphics) [0x7fff85c9ce92]
1 CGSPostLocalNotification + 591 (CoreGraphics) [0x7fff85c599a4]
1 display_notify_proc + 25 (CoreGraphics) [0x7fff85eddc66]
1 get_display_logging + 62 (CoreGraphics) [0x7fff85c26ee7]
1 get_current_display_system_state + 85 (CoreGraphics) [0x7fff85c2207e]
1 CGSGetDisplaySystemState + 152 (CoreGraphics) [0x7fff85c22198]
1 CGSDisplaySystemStateCreateFromSerialization + 127 (CoreGraphics) [0x7fff85c22383]
1 CGSDisplaySystemState::decode(CGSDecoder&) + 295 (CoreGraphics) [0x7fff85c225c9]
1 CGSDisplayState::decode(CGSDecoder&) + 1181 (CoreGraphics) [0x7fff85c22aff]
1 CGSDisplayMode::decode(CGSDecoder&) + 322 (CoreGraphics) [0x7fff85c22f46]
3 start_wqthread + 13 (libsystem_pthread.dylib) [0x7fff8a14cfb9]
3 _pthread_wqthread + 314 (libsystem_pthread.dylib) [0x7fff8a149ef8]
3 _dispatch_worker_thread2 + 40 (libdispatch.dylib) [0x7fff8a744193]
3 _dispatch_root_queue_drain + 75 (libdispatch.dylib) [0x7fff8a742fa3]
3 _dispatch_queue_invoke + 110 (libdispatch.dylib) [0x7fff8a7449dd]
3 _dispatch_queue_drain + 451 (libdispatch.dylib) [0x7fff8a74368f]
3 _dispatch_client_callout + 8 (libdispatch.dylib) [0x7fff8a7412ad]
2 CA::CG::Queue::render_callback(void*) + 277 (QuartzCore) [0x7fff8a27aa33]
2 CA::CG::DrawOp::render(CA::CG::Renderer&) const + 2770 (QuartzCore) [0x7fff8a269c68]
1 CA::CG::DrawPathShadow::draw_shadow(CA::CG::Renderer&, bool) const + 548 (QuartzCore) [0x7fff8a270cb2]
1 CA::CG::fill_path_blurred(CA::CG::Renderer&, CGPath const*, CA::Rect const*, float, CA::ScanConverter::FillRule, CA::Mat2<double> const&, bool) + 2473 (QuartzCore) [0x7fff8a26fe5d]
1 CA::CG::MosaicDelegate::draw_array() const + 117 (QuartzCore) [0x7fff8a268f83]
1 CA::OGL::Context::array_flush() + 62 (QuartzCore) [0x7fff8a190f42]
1 CA::OGL::GLContext::draw_elements(CA::OGL::PrimitiveMode, unsigned int, unsigned short const*, CA::OGL::Vertex const*, unsigned int, unsigned int, CA::OGL::ClipPlane const*) + 397 (QuartzCore) [0x7fff8a191105]
1 glDrawRangeElements_IMM_Exec + 341 (GLEngine) [0x7fff8946bac6]
1 gleDrawArraysOrElements_ExecCore + 598 (GLEngine) [0x7fff89472b53]
1 gleBeginPrimitiveTCLFunc + 122 (GLEngine) [0x7fff894c741e]
1 CA::CG::DrawPathShadow::draw_shadow(CA::CG::Renderer&, bool) const + 272 (QuartzCore) [0x7fff8a270b9e]
1 CA::CG::FillRoundedRectShadow::retain_path(CA::CG::Renderer&, CA::Vec2<double>&) const + 245 (QuartzCore) [0x7fff8a27667b]
1 CA::CG::Renderer::retain_simple_path(CGRect const&, CGSize const*) + 243 (QuartzCore) [0x7fff8a27c033]
1 CA::CG::Queue::render_callback(void*) + 293 (QuartzCore) [0x7fff8a27aa43]
1 CA::CG::DrawOp::render(CA::CG::Renderer&) const + 2770 (QuartzCore) [0x7fff8a269c68]
1 CA::CG::DrawImage::draw_image(CA::CG::Renderer&, bool) const + 109 (QuartzCore) [0x7fff8a26d451]
1 CA::CG::fill_image(CA::CG::Renderer&, CGImage*, CA::Rect const&, CA::Mat2<double> const&, bool, bool, CGInterpolationQuality, CA::Bounds const*) + 2755 (QuartzCore) [0x7fff8a26cd62]
1 glDrawRangeElements_IMM_Exec + 265 (GLEngine) [0x7fff8946ba7a]
1 gleDoDrawDispatchCore + 502 (GLEngine) [0x7fff894a82a4]
1 gldUpdateDispatch + 1052 (GeForceGLDriver) [0x1234402f4b09]
1 ??? (GeForceGLDriver + 3097151) [0x1234402f423f]
1 __pthread_set_self + 16 (libsystem_pthread.dylib) [0x7fff8a14cfac]
1 <Kernel mode>
Binary Images:
0x1091f0000 - 0x1091f0ff4 com.apple.WebKit.WebContent 9537 (9537.74.9) <46AD5B20-A90A-329C-8A8C-18A9062AA559> /System/Library/PrivateFrameworks/WebKit2.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
0x123440000000 - 0x123440882ff7 com.apple.GeForceGLDriver 8.24.9 (8.2.4) <D25CEAA2-7269-3476-8A38-8C78D74D411B> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x7fff8485a000 - 0x7fff8485dff7 libdyld.dylib (239.4) <CF03004F-58E4-3BB6-B3FD-BE4E05F128A0> /usr/lib/system/libdyld.dylib
0x7fff85c1f000 - 0x7fff8653eaf3 com.apple.CoreGraphics 1.600.0 <06212100-8069-31A1-9C44-F6C4B1695230> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff886ae000 - 0x7fff886b4ff7 com.apple.XPCService 2.0 (1) <2CE632D7-FE57-36CF-91D4-C57D0F2E0BFE> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fff8879a000 - 0x7fff88b11ffa com.apple.JavaScriptCore 9537 (9537.74.4) <0942FE6B-3152-30FC-B92A-92A1C29C5295> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff893c3000 - 0x7fff89550ff7 GLEngine (9.6) <51D58F76-B9B3-3B4F-B65A-F6D213C2EED7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff8a14f000 - 0x7fff8a2ebff3 com.apple.QuartzCore 1.8 (332.3) <80F1068F-4A34-34FB-9E05-A2DC0700D2F2> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff8a43e000 - 0x7fff8a462fff libxpc.dylib (300.90.2) <AB40CD57-F454-3FD4-B415-63B3C0D5C624> /usr/lib/system/libxpc.dylib
0x7fff8ceb7000 - 0x7fff8d0a7ffd com.apple.WebKit2 9537 (9537.74.9) <3F7B257F-D0DA-3AA8-BE8B-0C5474FE9806> /System/Library/PrivateFrameworks/WebKit2.framework/Versions/A/WebKit2
0x7fff8dc64000 - 0x7fff8eab2fff com.apple.WebCore 9537 (9537.74.11) <9683BA7C-A04B-3E33-B195-DCF1C2CABF95> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
Powerstats for: hidd
Start time: 2014-04-02 16:03:27 -0400
End time: 2014-04-02 16:03:53 -0400
Microstackshots: 5 samples (7%)
Primary state: 4 samples Non-Frontmost App, Non-Background Priority, Kernel mode
User Activity: 0 samples Idle, 5 samples Active
Power Source: 0 samples on Battery, 5 samples on AC
5 thread_start + 13 (libsystem_pthread.dylib) [0x7fff8a14cfc9]
5 _pthread_start + 137 (libsystem_pthread.dylib) [0x7fff8a14872a]
5 _pthread_body + 138 (libsystem_pthread.dylib) [0x7fff8a148899]
5 __IOHIDSessionStartOnThread + 695 (IOKit) [0x7fff86bdb906]
5 CFRunLoopRun + 97 (CoreFoundation) [0x7fff81de6811]
5 CFRunLoopRunSpecific + 309 (CoreFoundation) [0x7fff81d310b5]
4 __CFRunLoopRun + 1161 (CoreFoundation) [0x7fff81d31779]
4 __CFRunLoopServiceMachPort + 181 (CoreFoundation) [0x7fff81d32155]
4 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8a773a1a]
1 __CFRunLoopRun + 1830 (CoreFoundation) [0x7fff81d31a16]
1 __CFRunLoopDoSource1 + 478 (CoreFoundation) [0x7fff81d4091e]
1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41 (CoreFoundation) [0x7fff81d409a9]
1 __CFMachPortPerform + 388 (CoreFoundation) [0x7fff81d40b44]
1 mt_DequeueMultitouchDataMachPortCallBack + 142 (MultitouchSupport) [0x7fff812f8ceb]
1 mt_HandleMultitouchFrame + 984 (MultitouchSupport) [0x7fff812f9bfd]
1 mt_ForwardBinaryContacts + 542 (MultitouchSupport) [0x7fff812fd734]
1 MTSimpleHIDManager::handleContactFrameEntry(__MTDevice*, MTContact*, int, double, unsigned long long, void*) + 13 (MultitouchHID) [0x10b72f84b]
1 MTTrackpadHIDManager::handleContactFrame(__MTDevice*, MTContact*, int, double, unsigned long long, void*) + 231 (MultitouchHID) [0x10b7307c1]
1 MTParser::handleContactFrame(MTContact*, int, double, unsigned long long, __IOHIDEvent**, __IOHIDEvent**, double*) + 597 (MultitouchHID) [0x10b71c21d]
1 MTParser::createHIDCollectionEventsForHand(MTPathStates const&, MTHandStatistics const&, MTHandMotion const&, unsigned int) + 324 (MultitouchHID) [0x10b71cb62]
1 IOHIDEventCreateDigitizerEvent + 120 (IOKit) [0x7fff86bce7c7]
1 __IOHIDEventCreate + 53 (IOKit) [0x7fff86bce10f]
1 <User mode>
Binary Images:
0x10a4a0000 - 0x10a4a0fff hidd (503.90.3) <64C49EE7-88C4-39A1-BBC3-79B63ABC75A0> /usr/libexec/hidd
0x10b715000 - 0x10b740fff com.apple.iokit.plugin.MultitouchHID 245.13 (245.13) <2084DEA8-7175-3EEF-AD53-243833C23912> /System/Library/Extensions/AppleMultitouchDriver.kext/Contents/PlugIns/MultitouchHID.plugin/Contents/MacOS/MultitouchHID
0x7fff812f5000 - 0x7fff81307ff7 com.apple.MultitouchSupport.framework 245.13 (245.13) <4A5857F9-E249-3FA6-ADBB-410606AEC8CE> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff86ba6000 - 0x7fff86c10ff7 com.apple.framework.IOKit 2.0.1 <A779DE46-BB7E-36FD-9348-694F9B09718F> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
Powerstats for: WindowServer
Start time: 2014-04-02 16:03:40 -0400
End time: 2014-04-02 16:04:07 -0400
Primary state: 3 samples Non-Frontmost App, Non-Background Priority, Kernel mode
4 main + 9 (WindowServer) [0x109810f96]
4 CGXServer + 807 (CoreGraphics) [0x7fff85d401b6]
4 CGXRunOneServicesPass + 164 (CoreGraphics) [0x7fff85d3f979]
4 run_timer_pass + 379 (CoreGraphics) [0x7fff85e7cff6]
4 update_display_callback + 125 (CoreGraphics) [0x7fff85e00671]
2 CGXUpdateDisplay + 8838 (CoreGraphics) [0x7fff85e029bb]
2 CGXReleaseDisplayDeviceSurface + 197 (CoreGraphics) [0x7fff85e449bb]
2 CGXGLAccelFinish + 156 (CoreGraphics) [0x7fff85e97255]
2 ??? (GeForceGLDriver + 3100771) [0x1234402f5063]
1 ??? (GeForceGLDriver + 3101325) [0x1234402f528d]
1 ??? (GeForceGLDriver + 3011924) [0x1234402df554]
1 ??? (GeForceGLDriver + 3012747) [0x1234402df88b]
1 <User mode>
1 ??? (GeForceGLDriver + 3101187) [0x1234402f5203]
1 gpusSubmitDataBuffers + 141 (libGPUSupportMercury.dylib) [0x7fff84571508]
1 IOAccelContextSubmitDataBuffers + 242 (IOAccelerator) [0x7fff88796754]
1 IOConnectCallStructMethod + 56 (IOKit) [0x7fff86baac32]
1 IOConnectCallMethod + 349 (IOKit) [0x7fff86baaa30]
1 io_connect_method + 377 (IOKit) [0x7fff86c02a2e]
1 CGXUpdateDisplay + 10574 (CoreGraphics) [0x7fff85e03083]
1 finalize_CoreAnimation_update_state + 101 (CoreGraphics) [0x7fff85e08c65]
1 CGXCollectSurfaceBacking + 123 (CoreGraphics) [0x7fff85ef2536]
1 WSBackingStoreSetPurgeable + 43 (CoreGraphics) [0x7fff85de014a]
1 IOAccelSurfaceControl + 74 (IOKit) [0x7fff86bb4be8]
1 IOConnectCallScalarMethod + 46 (IOKit) [0x7fff86baacb5]
1 IOConnectCallMethod + 266 (IOKit) [0x7fff86baa9dd]
1 CGXUpdateDisplay + 8689 (CoreGraphics) [0x7fff85e02926]
1 CGLayerComposite + 116 (CoreGraphics) [0x7fff860ab3f8]
1 CGXGLAccelComposite + 1233 (CoreGraphics) [0x7fff85e9b43d]
1 gl_composite_layers + 38 (CoreGraphics) [0x7fff85e9bc7e]
1 gl_composite_layer + 479 (CoreGraphics) [0x7fff85e9fdc9]
1 gl_composite_layer_core + 570 (CoreGraphics) [0x7fff85ea42de]
1 gl_composite_core_animation + 2004 (CoreGraphics) [0x7fff85e9d3f8]
1 CARenderOGLRenderDisplay + 82 (QuartzCore) [0x7fff8a226174]
1 CA::OGL::render(CA::OGL::Renderer&, CA::Render::Update*) + 236 (QuartzCore) [0x7fff8a18d0ef]
1 CA::OGL::Renderer::render(CA::Render::Update const*) + 714 (QuartzCore) [0x7fff8a18d430]
1 CA::OGL::render_root_layers(CA::OGL::Renderer&, x_link_struct const*, CA::OGL::Gstate const&) + 331 (QuartzCore) [0x7fff8a194afb]
1 CA::OGL::render_layers(CA::OGL::Renderer&, CA::OGL::Layer*) + 144 (QuartzCore) [0x7fff8a1977b5]
1 CA::OGL::ImagingNode::render(CA::OGL::ImagingNode::RenderClosure*, unsigned int) + 433 (QuartzCore) [0x7fff8a1979e1]
1 CA::OGL::LayerNode::apply(float, CA::OGL::Surface**, float*) + 220 (QuartzCore) [0x7fff8a1989d6]
1 CA::OGL::LayerNode::apply(float, CA::OGL::Surface**, float*) + 57 (QuartzCore) [0x7fff8a198933]
1 CA::OGL::render_contents_background(CA::OGL::Renderer&, CA::OGL::Layer const*) + 2486 (QuartzCore) [0x7fff8a19954b]
1 CA::OGL::render_background(CA::OGL::Renderer&, CA::OGL::Layer const*) + 86 (QuartzCore) [0x7fff8a199670]
1 CA::OGL::render_solid_background(CA::OGL::Renderer&, CA::OGL::Layer const*, unsigned int, CA::Render::Pattern*) + 1138 (QuartzCore) [0x7fff8a199b21]
1 CA::OGL::fill_round_rect(CA::OGL::Context&, CA::OGL::RectState const&, double) + 67 (QuartzCore) [0x7fff8a19a56b]
1 CA::OGL::fill_rect(CA::OGL::Context&, CA::OGL::RectState const&) + 176 (QuartzCore) [0x7fff8a19a80b]
1 CA::OGL::emit_one_part_rect(CA::OGL::Context&, CA::OGL::RectState const&, float const*, unsigned int) + 1111 (QuartzCore) [0x7fff8a19adc6]
1 CA::OGL::Context::ClippedArray::next_rect(CA::Bounds&) + 322 (QuartzCore) [0x7fff8a19b06e]
1 gldUpdateDispatch + 913 (GeForceGLDriver) [0x1234402f4a7e]
1 ??? (GeForceGLDriver + 3172421) [0x123440306845]
1 ??? (GeForceGLDriver + 2166846) [0x12344021103e]
1 <User mode>
1 thread_fun + 25 (QuartzCore) [0x7fff8a1762ad]
1 CA::Render::Server::server_thread(void*) + 195 (QuartzCore) [0x7fff8a176377]
Binary Images:
0x109810000 - 0x109810ffd WindowServer (599.20.11) <1A1CC705-012E-3B8D-95FB-6E1883EA2952> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/CoreGraphics.framework/Resources/WindowServer
0x7fff8456e000 - 0x7fff84579fff libGPUSupportMercury.dylib (9.6) <3E5636DB-5EED-3C31-8B6D-8CBFE965BC12> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff88795000 - 0x7fff88799fff com.apple.IOAccelerator 98.14 (98.14) <13EE735B-BD43-3E9B-9908-E423A17C4517> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
Victor - sorry you are having problems with this.
Is Octane Standalone 1.5 working on your Mac?
Victor2112
Yes, Octane 1.5 is working great. :)
I did download the 1.51 update but have not installed it.
Thanks Victor
I can only think that the installer has placed the plugin in the wrong folder.
Could I trouble you pls to take a screenshot of your Poser folder showing the runtime folder, through to the Python\addons\OctaneRender for Poser\OSX folder - so I can see the files and dates pls.
Victor2112
I see what happened now, it installed the OctaneRender for Poser into a Poser Pro 2014>Runtime>Python>addons>OctaneRender for Poser folder.
I attached the Poser 10 folder path as requested.
However, when doing so, I noticed that I now have a Poser Pro 2014 folder and that it only has a Runtime>Python>addons>OctaneRender for Poser folder. I do not own Poser Pro 2014 so the Runtime>Python....Octane folder path is the only one in there.
I did copy the OctaneRender for Poser folder into the Poser 10>Runtime>Python>addons folder but it crashed Poser 10 each time. I can post the crash report if you like but it is very long.
And thank you for taking the time to help me with this.
Return to “Poser”
