Hi.
Attached is a video showing what appears to be a refraction difference between specular w/ and w/o dispersion. My understanding was that dispersion does not change the "center" refraction angle, but only disperses the wavelength-dependent refraction angles ABOUT that center. Therefore, should not the overall depth of the image behind the glass appear exactly the same w/ and w/o dispersion?
Dispersion Changes IOR?
Octane uses Cauchy's equation for dispersion. The index input becomes the B parameter, and the Dispersion Coefficient is the C parameter. The average index of refraction becomes a bit larger than the index setting.
Wikipedia article here: http://en.wikipedia.org/wiki/Cauchy%27s_equation
Roeland
Roeland
