Version 1.52.1 (Octane Render 1.52) *** 10.04.2014 ***
miohn
Hi Ahmet,
havn't installed a video capture prog,
but not neccessary here.
My material preview looks like this. Grey.
From time to time it is flipping between showing the texture
and grey like in the screenshot.
I have have 2 Titans .
Whatelse could this cause?
Like I said, I haven't had this problem with 1.21 and earlier.
regards
Mike
wireframex
aoktar wrote:
wireframex wrote:Hey Aoktar !!
Here Octane is 1.50.2 but SDK is 1.37 ?
Forgot something ?
Phil
no, if you saved Octane dialogs to layout, c4d shows old texts. Close and reopen pls
Its the same ... :(
Log tells me
"Started logging on 29.03.14 12:44:46
OctaneRender version 1.50 (1500001)
ACTIVATION_OK
closeOctaneDialog
---->>>> closeRenderDialog 0x0000000000000000
Can't Read Preset File: C:\Program Files\MAXON\CINEMA 4D R15\plugins\c4doctanepresets.dat
Can't Read Preset File: C:\Program Files\MAXON\CINEMA 4D R15\plugins\c4doctanepresets.dat"
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 560.70 - Octane Plugin Build 2023.1.3.141
Licensed: Softimage 2012 SP1 / Lightwave 2024.0.1 / Rhino 8.9
miohn
Hi Aoktar,
please see attached video!
Capture.mp4
(1.95 MiB) Downloaded 3769 times
regards
Mike
mike, I see but couldn't produce this problem on my computers. i can dig if I have.
for sdk 1.37 text, if you see a text as 1.50.003 in console and plugin hasn't any crashes it should be sdk 1.50.
Oleg
Ok, another non critical error: kernel "Deep Channel" mode Wire won't work in full screen. 100% stable error. Probably my card can't render?
https://www.youtube.com/watch?v=21mpedY ... e=youtu.be
Log says:
"--------------------------- EXPORT LOG ---------------------------
Export materials time= 153.316 ms
Collect objects time= 0.649 ms
Meshes creation time = 66.753 ms
Octane voxelization time = 0 ms
Sending to Octane engine time = 1.061 ms
Total export Time = 924.983 ms
CUDA error 1 on device 0: One or more of the parameters passed were not within an acceptable range of values.
-> Failed to launch kernel (wireframe)
CUDA device 0: Info kernel failed
<<< Render Failure >>>
COPY PRESET TO:P:\C4D\tex\HDRI (Uffizi).HDR
Tried to access null item"
Oleg, put this file to same place as c4d.exe. This will slowdown everything but will show more info. Copy octane log to a file then send me. Seems as a gpu problem
octane_log_flags.txt
(89 Bytes) Downloaded 265 times
cyartist
Hi
I am having the same issue with 1.50... versions. Material shows up grey in preview.
Also Dialog says SDK 137.
No problems in prior versions 121.
Oleg
aoktar wrote:Oleg, put this file to same place as c4d.exe. This will slowdown everything but will show more info. Copy octane log to a file then send me. Seems as a gpu problem
Did like you said, nothing really slows down. Not sure if this log is more helpful but any way.
octane 1.50 140330 111357.log
(2.84 KiB) Downloaded 264 times
Uhmmgg, Big sorry to all. Log file of Oleg is showing that a mistake on compilation. Plugin was compiled with 1.37, i'll fix asap.
So 1.37 texts was correct and this is reason of disappearing textures.
Oleg
Glad I could "help" with something x))
