Bug Report
TonyZagoraios
Hello to all
Just purchased Octaner Render Standalone and Cinema 4D Plugin.
I installed the standalone and its all fine plus the CUDA Drivers but when i paste the cinema p4dplugin into the cinema 4d plugin folder..then my Cinema 4D docent open and it shows me the message of a bug report and the Cinema crashes.
Im using a Mac Pro machine with Macosx 10.9.2 and CINEMA 4D R13.
Any help would be appreciate!!
Thanx
Tony
PS.im attaching a crash report.
Bug Report
Bug Report
Screen Shot 2014-03-29 at 3.39.27 PM.png (29.16 KiB) Viewed 4835 times
be sure you have correct files and
one octane-r13.dylib, not for r14 or r15
TonyZagoraios
aoktar wrote:be sure you have correct files and
Hello..thank you but i have done that..:)
ok, there is no other reason. if it couldn't loaded correct octane files, will be failed on startup.
pls show me files you have, is it for 1.00?
TonyZagoraios
Yes..it fails on the startup..it doesn't let Cinema 4D to start.
Som uploading the following 2 stills..one for the cinema plugin i run and one for the standalone version.im using 1.5 version of standalone app.
TonyZagoraios
Also...
is it 1.50 of plugin? could you try with only octane
TonyZagoraios
aoktar wrote:is it 1.50 of plugin? could you try with only octane
Can you guide me to the right download link..in case i haven't download the latest.:)
Seems very strange to me..it is crucial for me the plugin..!!
this is stabile build but old
http://render.otoy.com/forum/viewtopic.php?f=30&t=36331
this is last version of plugin which is going to be stabile, but not yet
http://render.otoy.com/forum/viewtopic.php?f=30&t=38965
TonyZagoraios
aoktar wrote:this is stabile build but old
No solution unfortunately...
I have really no idea why the plugin not even works but also crashes my Cinema 4D Application so it doesn't start.
I double checked that 1.5 stand alone works fine and of course i double checked i have the right plugin inside...:(
