Hi aoktar,
I think that I had accidently moved the float slider and when seeing the texture preview go away, I was curious.
Thanks for the video on correct usage.
Yes the file was unsaved, but the texture paths were already set in both C4d prefs and in Octane plug-in settings before
I added any elements to the scene.
Version 1.52.1 (Octane Render 1.52) *** 10.04.2014 ***
Not sure if this is issue, but anyway have a look
https://www.youtube.com/watch?v=8y_gi-U ... e=youtu.be
looks like a object cache problem internally. What kind of effect is there except symetry?Oleg wrote:Not sure if this is issue, but anyway have a look
i'm not sure what are you doing, but it's working as in picture. Can you be more spesific?NVN wrote:hi aoktar.
C4d-hair wont work anymore....
I have some gras (generate Polyons aktivate) and a turbulence-deformer.
My hair will only looks like the first frame??
Same thing on our PC's. New layout says 1.50.2 SDK 1.37aoktar wrote:no, if you saved Octane dialogs to layout, c4d shows old texts. Close and reopen plswireframex wrote:Hey Aoktar !!
Here Octane is 1.50.2 but SDK is 1.37 ?
Forgot something ?
Phil
On our Mac's it says 1.50.2 SDK 1.50
Both machines are refreshed layouts
1 Dell Z840 with 2x Titan XP's
2 Digital Storm Hailstorm/Win8/32GB/EVGA Titan x4
2 Server blades with 4 Tesla K80's
1.50.3 still has the problem with dissapearing image in
material preview!
When touching and moving just a little bit the slider for "roughness" f.e.
the texture image on the sphere in the preview window turns to light grey.
It renders correct in LiveViewer.
But I cannot get the image back in material manager and preview.
Did'nd change anything on my settings since 1.2... and that definately worked well
bevor 1.23
regards
Mike
material preview!
bevor 1.23
regards
Mike
i can't see any problem like that. Else anyone? Please send me a PM with a video capturemiohn wrote:1.50.3 still has the problem with dissapearing image in
material preview!
bevor 1.23
regards
Mike
There is nothing else special except Symmetry, just geometry and nulls. If I turn off Symmetry, this glitches disappear btw. And it is not affected to the final render. Pretty sure you have more important things to do, just letting you know.aoktar wrote:looks like a object cache problem internally. What kind of effect is there except symetry?Oleg wrote:Not sure if this is issue, but anyway have a look
