Version 1.52.1 (Octane Render 1.52) *** 10.04.2014 ***
lucioing, what do you mean pls?
wireframex
Hey Aoktar !!
Here Octane is 1.50.2 but SDK is 1.37 ?
Forgot something ?
Phil
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 560.70 - Octane Plugin Build 2023.1.3.141
Licensed: Softimage 2012 SP1 / Lightwave 2024.0.1 / Rhino 8.9
wireframex wrote:Hey Aoktar !!
Forgot something ?
Phil
no, if you saved Octane dialogs to layout, c4d shows old texts. Close and reopen pls
lucioing
Hi Ahmet!
I mean what I wrote! I have problems in refresh screen as you can see in the screenshot.
What you see is what I have on my screen.
The priority is set to low, as default...
Is the 1.50.2 a stable release? Which one I have to use?
Thank you again, Ahmet!
Lucio
Mac Pro 5.1 -16 GB- 2 x Titan Black 6GB - Titan Z - MacOS Yosemite 10.10.4
lucioing wrote:Hi Ahmet!
Lucio
Hi dear friend,
what is causing this? Liveviewer or plugin? Did you tried to remove plugin also? I have no else reports this. This versions are stabile candicate, i'm going to fix if any problem occurs and will release a stabile version
lucioing
What about filter on textures?
L.
lucioing wrote:What about filter on textures?
L.
teorically it's possible, but filters refer to c4d and will be rendered to some textures before render process. you can change render texture size from settings. But this is a that takes some extra time
lucioing
Here's the screenshot.
About refresh problems: it happens when I work with 4 views. It seems that with ONLY ONE view, it's ok.
lucioing
L.
Please Ahmet, could you explain to me how to do that? It's very important in my workflow...
Thank you
L.
lucioing wrote: Please Ahmet, could you explain to me how to do that? It's very important in my workflow...
Thank you
L.
could you try imagetexture?
