What's the best way to copy materials between scenes? It would be nice if I could just use Modo's right click --> save preset on an override and load that in another scene.
The best way is to "Save as Preset" in the OctaneRender Setup window - however an issue has been reported where this is not working correctly - and will be fixed in the next release.
Also is it possible to get materials created in the Standalone into Modo?
This is theoretically possible to implement right now (I believe the API supports this), however the plugin would need to be modified to support this. It's on the TODO list, but will take some time before it's implemented.
When adding images as textures and trying to changes the settings, Octane will give an error on any settings I try.
I Zay - I have not been able to replicate this. Does it happen on a new scene for you - or just that scene. Does restarting Modo fix the problem?
