New version 1.23.2 (SDK 1.37) *** 25.03.2014***
shawnfrueh wrote:Does the Object tag only see local values? If I have only one object in a hierarchy with an object tag the object does not update when moving the parent object.
A local and world toggle on the Object tag would be really nice.
not possible due algoritm. We are using c4d's some flags to detect updates. if you don't move object what will not trigger some flag. Some other method can't give so fast feedbacks
djart
Hello aoktar,
1. i have some problems with the liveviewer output and the rendered output. It looks different and wont render what it shows on the LV.
I attached 2 images that show what i mean. The upper image shows the LV output and the lower shows the rendered output.
Once it does not shows emission objects (Interiour Image - the lamp and the green (fake)colorbleedemission object from the wall) and it seems to have problems with using a sunlight and a sphere with hdr for reflections (car image)?!
The settings from liveviewer are copied to post. I used the newest build on R13/ Win7. I just switched from c4d 1,13 to the newest one, but the problem appeared on older versions also.
Used Standalone Version http://render.otoy.com/forum/viewtopic.php?f=33&t=38791
Used C4D Version http://render.otoy.com/forum/viewtopic. ... 33#p164852
The car scene is sent to you by PM.
2. Also klicking on the button "graph", c4d crashes!
3. It still not recognizes all materials for a MIX mat. After delete all unused material the inserted mixmats are gone too.
cheers,
djart
Ron
aoktar wrote:Ron, can you check what's is correct on lines? dark color shows that a gpu is disabled. I think there is a mistake on displaying the lines
Yes - if the GPU order in settings equals GPU order in live viewer then the percentage numbers is mixed. First number should be changed with second number.
Had always the feeling that the 'Use prority" is not corresponding to what is shown in live viewer. Now we know why.
Regards - Ron
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
Rudi
Note since ancient times. Not corrected so far yet.
NVN
mybe there is something wrong with the liveDB.
In C4D i cant see tony's new skin shader.....now i installed 1.5 Standalone and it show up correctly?
NVN wrote:mybe there is something wrong with the liveDB.
i don't know maybe need cache cleanup or may not exposed to plugins
NVN
how can i cleanup my cache in octane?
a little bit strange, u dont think so?
hi, the live-db is version dependent now, so we can't see the new materials added with v1.5 until we have a c4doctane build with the 1.5 sdk, i think :roll:
ciao beppe
AndreaMannori
Hi, with this release I have some little OpenGl issues, for example: in the viewport I can't see the selected object contour, its axis and the absolute axis. An overall viewport performance reduction. If I remove c4dOctane plugin the problem disappears.
Thank you in advance.
Andrea Mannori
win 8.1 x64; nvidia 770M driver 340.52; octane standalone 2 + c4doctane 2.
David_S
Hi Aoktar,
the preview for animation is gone.
What is the «Experimantal»-button for?
ciao, David
