OctaneRender for Modo (OS X) 1.55 [OBSOLETE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Modo 1.5 - TEST RELEASE.
Modo Version
This version requires Modo701 SR4 or later, or Modo801 on Macintosh OS X Lion, Mountain Lion and Mavericks. It may run on Snow Leopard - but this has not been tested. See separate thread of the Windows version.
Nvidia Driver Version
This release requires Nvidia drivers 335.23 or later.
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Modo version and SR number
- OctaneRender for Modo version (ie. 1.33.0.41)
- List what other plugins you have installed for Modo
- The most important part of resolving a problem is me being able to re-produce that problem. So pls provide as much detail as possible in order for me to do this, and if the problem is specific to the scene, send me the scene.
Change Log
- N/A
Known Issues
- On rare occasions, clicking the Octane Override in the Shader Tree stops selecting the workspace for that Octane material. If this occurs, pls let me know the steps you took prior to that
- Render statistics will not update unless you move the mouse. This is a Modo OS X bug, which has been reported to TheFoundry.
For more information...
- Read the on-line manual
- Watch the "Getting Started" video http://vimeo.com/87048593
- Read the FAQ
- Read the Troubleshooting guide
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Download the plugin from the following links:
- OctaneRender for Modo 1.55.0.72 beta (OSX)
I have refreshed the update installer with 1.33.0.47. Pls refer to the Window TEST thread for the change log.
DRMJ14
Thank you very much for making this plugin for mac available so quickly after you released the Windows version. I am very keen to incorporate Octanerender into my workflow and I thought that the mac version would only become available late in the year.
I just found an issue with the above installer, which is now rectified, and re-uploaded. So if you have already downloaded the above version, pls re-download and install it.
riggles
Is it safe to use this with the 1.5 Standalone?
Yes.
simplyfabio
In case of a dual boot machine, if I've two licenses of octane standalone, can I use the same license for modo, for both windows and osx? Thank you for your work!!
That is a very good question, and I'm not sure the answer. I haven't actually tried running the same license on my dual boot Win/Mac PC - I'll try tomorrow.
EDIT: Would a single license of Standalone work in this instance? If Standalone required two licenses, the plugin probably will too - but I'll check to be certain.
riggles
When I boot into Windows on my Mac, I need to deactivate both the Standalone and plugin on OTOY's website before I can activate and use them in Windows.
I have an Octane 1.50 version of the plugin available, however there is an issue which is preventing it from working correctly, so I have deferred the release (which matches the Windows version just released) until I have a resolution. I will post here when I have more info.
Return to “Foundry Modo”
