modify a shader on multiple different objects
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\SetupForm.py", line 1694, in MenuSelectionCb
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 909, in MenuCommand_ReimportSceneMaterialsFromPoser
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 183, in ConvertMaterial
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 642, in createOctaneMaterialFromPoserShaderTree
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 625, in createOctaneMaterialFromPoserShaderTree
ValueError: invalid literal for float(): 0.5_2
I am sorry for the troubles you are having. However I cannot reproduce this error. I think it is either a) because you saved the Octane material to the Poser material with 1.20 and are trying to reconvert with 1.29, OR b) there is something specific in the material you are saving to the Poser material which is causing the problem.
So I can resolve this, can you pls save that material (that is causing the error above) to the Poser material of a cube (Poser primitive prop), and save that cube in a separate pz3 file and send me that pz3 file (so the pz3 will just have the cube and the Octane material giving you the above error saved to the cubes Poser material).
I hope that makes sense!
Andygraph3D
Send the pz3 here ? Or to your e-mail ?
Either attach to this thread as a zip file, or email me at paul at physicalc-software dot com.
Andygraph3D
This is the pz3 with a sphere inside with octane shader applied to it.
octanemat2poser.zip
(13.71 KiB) Downloaded 249 times
Thanks. If I load that scene, open the plugin, select Reconvert From Poser for the ball_1 Preview material it works without error. Can you pls doublecheck that you get the above error when doing this?
Also, exactly what release are you using pls?
Andygraph3D
the plugin is 1.20.2.7 32bit on poser 10
if i try to reconvert only the sphere i don't found problem, no error ..
BUT, if i create a new prop (example a cube) and i copy and paste the octane material from sphere to cube and try to reconvert it, i see the same error message again on sphere or on cube:
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\SetupForm.py", line 1691, in MenuSelectionCb
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 872, in MenuCommand_ReimportPropFigureMaterialsFromPoser
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 1574, in MemoriseTreeState
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 1566, in MemoriseTreeState
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 2238, in displayError
ValueError: Error: null tree view in MemoriseTreeState for pin diffuse
Andygraph3D
I have understand if i convert the materials from octane to poser and then reconvert material from poser to octane, i dont have error.
but if i try to copy and paste the octane material from a prop to another one and then reconvert the material from poser to octane,
BAM! error message
I'm sorry, I don't understand what material you are copy/pasting. The octane material or the Poser material?
I did the following:
1) Opening your scene (reconnected the missing texturemaps)
2) Plugin Material tab->ball1->Preview->Save Octane Nodes to Poser Material
3) Poser Material Room, save Preview to the Material Library.
4) Loaded a new cude into the scene
5) Poser Material Room, load the saved material from the Poser Material Library into the material of the cube
6) Back to the Poser plugin, Material tab, select cube, Reconvert This Material From Poser -> the material from the sphere is correctly applied.
No crashes.
This is the workflow you need for copying one material to many. If you have 100 cubes, step 5.5 would be to use a Poser material tool to apply the MAT pose to all 100 cubes in one go, then step 6) would be to Reconvert All Materials From Poser (for the whole scene).
I hope that helps.
Andygraph3D
no error, but don't load the octane material applied to cube prop
maybe i don't understand how save and load the material create from octane into poser:
this is the material saved from octane plugin into poser
Pls see page 160 of the Poser Pro 2014 manual.
Adding Materials to the Library Palette
Poser offers the option of saving either single materials, or
grouped material collections from a single figure, to the Library
palette.
To save single material to the Librarypalette:
1.  Open the Material Room.
2.  In the Library palette, select the desired Category/
Subcategory that will store the new material.
3.  Move the mouse into the Preview window, where it turns
into an Eyedropper tool. Use the eyedropper to “pick up” the
material that you want to save. The material settings appear
in the Simple or Advanced view in the Material room.
4.  Click the Save to Libraryicon (+) at the bottom of the
Librarypalette.
5.  In the New Material Set dialog, select the Single Material
radio button.
6.  Enter a name for the Material and click OK. A square
showing the single material appears in the currently selected
Material library category/subcategory.
Return to “Poser”
