Volume Fog
nagboy
Is there any way to enable this or achieve the effect with material tweaking. I need to create a realistic underwater scene and that is not easy without volume fog.
criko3d
just as an advice, you can easily make you r underwater scene using a zdepth of the scene, and use it as color correction in the most primitive way to do it, or use it as feed for fog effect in compositing software. best luck!
intel core i7-4960x 3.60 ghz
32 gb ram
win 7 64 bit
1x nvidia geforce gtx 780
1x nvidia geforce GTX TITAN
Return to “Autodesk 3Ds Max”
