OctaneRender™ Standalone 1.35
face
funk wrote: You should be doing the same thing in softimage too (I dont own it so not sure how to save a 1.0 EXR). Just to confirm what I'm saying a quick google search brought this up: http://www.workshop.mintviz.com/tutoria ... explained/
Here is a quote from that page:
Gamma correction summary
If you want to save the rendered image as a 32bit file format for compositing then don’t burn in the gamma, save at gamma 1.0 (linear). Gamma correction will be automatically applied when opening the file in post for the majority of software applications including Adobe Photoshop.
Looks we both are right.
The problem i have is to use in the plugin only the untonemapped result because i need a dynamic output.
This untonemapped image isn´t affected by the imager gamma.
So a change of the imager gamma to 1.0 has no effect to the untonemapped image and the result i become and see is the same as before.
I have also to revert the result to the output from 1.34 and then i must apply self a gamma correct to match the imager gamma value.
It´s all a little bit complicated to match all needs ;)
face
http://vimeo.com/user2509578
funk
face
The imager gamma has never affected the untonemapped image anyway (at least not in 1.20). If you want to see what the untonemapped EXR will look like you need to use an imager node with gamma set to 2.2 and response to LINEAR.
Octane is smart enough to save the image with a 1.0 gamma (linear) even though you are displaying it at 2.2. When you open in photoshop you will see exactly what you see on the octane screen because PS automatically applies the gamma correction to EXRs
face
funk wrote: The imager gamma has never affected the untonemapped image anyway (at least not in 1.20). If you want to see what the untonemapped EXR will look like you need to use an imager node with gamma set to 2.2 and response to LINEAR.
That´s correct.
But i can´t show a imager gamma of 1.0 with an untonemapped image without to add a calculation.
I must also only an other calculation as before, which is a little bit more complicated.
That´s what im mean to say...
face
User avatar (Default)
merid888
hi abstrax i can't open scene .obj or alembic in the versions 1.33, 1.34 and 1.35, is the same result, error, i add image
riggles
In OSX, replacing the previous application version with the newest one (v1.33 to 1.35) didn't work. It couldn't connect to my LiveAccount. I had to use AppZapper to remove the associated files and place the standalone app in my Applications folder fresh for it to authenticate and launch. Is this expected behavior?
roeland
merid888 wrote:hi abstrax i can't open scene .obj or alembic in the versions 1.33, 1.34 and 1.35, is the same result, error, i add image
Can you send us an object file which Octane can't load?
Roeland
merid888
sure, let me zip the file
regards
Recamara002.ABC
(10.21 MiB) Downloaded 253 times
Recamara 001_OR_ABC.zip
(19.86 MiB) Downloaded 257 times
roeland
Octane is missing some error handlers to handle unreadable files and the Alembic file seems to be missing some parts. Which application did you use to export this file?
Roeland
ROUBAL
Would it be possible to have the choice of Time and Frame Number for the timeline ? When searching a peculiar frame to compare with the original animation in case of render trouble, the Frame number is more useful than the time.
cakeller98
I think I found a bug in the mix node.
I'm mixing 2 specular materials. one with scattering and the other was supposed to just be for reflection. However, when the mix slider is 100% the specular for the opposite material is used. IOW the second material's specular value is used with the rest of the first material, and vice versa when at 0%
Here's the example material and mix node - did I do something wrong? or is this really a bug?
SwappedSpecular.zip
Material Example
(966 Bytes) Downloaded 223 times
EDIT: I'm trying to recreate this situation from scratch and am having trouble... maybe I did something whacked?
As of 2019-02-12
- Dell Precision 7710 w/Xeon E3-1535M v5 2.9GHz
- Windows 7 Pro, 64-bit (SP 1)
- 32 GB System Memory
- nVidia Quadro M5000M (Driver Ver 416.78)
- Standalone 4.0, 4.01.1, 4.02
- Maya 2018, 2019
Modo 12
Sketchup 2018, 2019
