OctaneRender™ for Blender 1.33 - 4.0 beta Win [OBSOLETE]
JimStar
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • New feature: now "Movable proxies" animation is fully implemented. In the very first draft, so you can test it...
How to use "Movable proxies" animation:
  • If you set "Animation mode" to "Full" - all geometry will be reloaded every frame. All meshes will be recalculated every frame, and all transforms will be reloaded, no matter what for type the meshes have. This is the most simple, robust, but slowest animation mode.
  • If you set "Animation mode" to "Camera only" - all geometry will be loaded in the first frame of animation, and only camera will be reloaded every frame. This is the fastest "camera fly" animation.
  • If you set "Animation mode" to "Movable proxies", you get most flexible animation mode, but most complicated to tune. In this mode, all "Global" and "Scatter" meshes will be loaded only in the first frame, and will not be refreshed in any of subsequent frames. For "Movable proxy" meshes - only transforms of these meshes will be reloaded in every frame. The more "Movable proxy" meshes you have (in comparison to "Reshapable proxy" meshes) - the faster will be the animation. It is usable if the meshes do not change its shape between frames and do not need to be recalculated by Octane. And for "Reshapable proxy" meshes - both transforms and mesh shapes itself will be reloaded every frame (meshes will be recalculated every frame by Octane). It is usable if you have some complicated animated meshes which change its shape between frames, but the more "Reshapable proxy" meshes you have - the slower will be the animation rendering.
All the same is true for Alembic export too.
Blender Octane Edition - 1.33 - 4.0 beta (2.69) (53.5MB autoinstaller file)
Octane Server - 1.33 - 4.0 beta (7.8MB autoinstaller file)
Happy blending.;)
voon
Hm, maybe I did something wrong. Deinstalled the old two apps, installed this. But now,when i render something in Blender and stop it (by using ESC), the renderserver doesn't stop ... it continues doing something (i guess just rendering, that continues). Blender will go back to editor etc, but the computer remains slow until I close the octane render server.
Ide
Hello, Jim
Is it possible to rotate HDR Environment Map with blender octane?
Nothing happens when I change the X and Y values in Octane rotate transform.
JimStar
voon wrote:Hm, maybe I did something wrong. Deinstalled the old two apps, installed this. But now,when i render something in Blender and stop it (by using ESC), the renderserver doesn't stop ... it continues doing something (i guess just rendering, that continues). Blender will go back to editor etc, but the computer remains slow until I close the octane render server.
Thanks, I will check it.
JimStar
Ide wrote:Nothing happens when I change the X and Y values in Octane rotate transform.
Z?..;)
Ide
Hello, Jim
What is the right way to install a new version?
1. Overwrite the old versions without uninstalling?
2. uninstall octane-server and octane Blender and install the new versions?
I think there is something wrong with octane rotation transform node when using HDRI maps.
How is it possible to rotate the HDRI map in horizontal?
voon
Deinstall old, reinstall new. Its quick enough with blender & octane. It keeps my settings, though .. I hope that can't somehow corrupt something :)
r-username
I have been using the alembic export feature with great success. I have notice that both thinlens and orthographic transfer over to octane standalone but if i use the panolens in blender, the alembic node in standalone is without a camera pin.
So im not sure if the blenderoctane is not exporting the panolens data or standalone is not reading the panolens data in the alembic file?
Or some way to switch to the pano lens once in standalone.
i7 960 - W7x64 - 12 GB - 2x GTX 780ti
http://www.startsimple.com/ - http://www.gigavr.com/
kubicki3d
Try using Translation Transform instead of Rotation. It works for me.
Cheers,
Szymon
i7 5960X | 64GB RAM | Win10 Pro | ASUS X99 Pro mobo | Chieftec 1250W psu
MSI GTX 780 Ti OC 3GB | 2 x GIGABYTE GTX 780 OC 3GB on USB risers | MSI GTX 750 Ti for display
Blender + Octane | C4D + Corona
Flickr profile: http://www.flickr.com/photos/kubicki3d
MattRM
For me, I can't export Alembic... snifff...
What I missed ?
https://vimeo.com/87879450
Need I desinstall before reinstall ?
Thank,
Matt[/color]
Return to “Blender”
