New version 1.23.2 (SDK 1.37) *** 25.03.2014***
Rudi
I really keep the fingers crossed for you. Up to now you have gained control of every problem.:)
shawnfrueh
I have a few requests. (using 1.18) I am working with HDR Light studio and have a nice setup to get it to work with Octane. The only problem is that the hdr's are flipped horizontally and I cannot get the texture transforms to fix that. Is it possible to get a flip vertical and flip horizontal added to ImageTexture? This would be extremely helpful!
Everything has been running smoothly with 1.18 Great work!
shawnfrueh wrote:I have a few requests. (using 1.18) I am working with HDR Light studio and have a nice setup to get it to work with Octane. The only problem is that the hdr's are flipped horizontally and I cannot get the texture transforms to fix that. Is it possible to get a flip vertical and flip horizontal added to ImageTexture? This would be extremely helpful!
Yes, it's possible with negative scale values. I'm not sure it's setted in gui controls properly.
Also, i should give a news for official Octane support in HDR Light Studio soon. This is really nice succes for the plugin.
Btw, 1.18 test1 version has a memory leak for float buffer on animation rendering. I'll release a fixed version asap.
djart
aoktar wrote "Also, i should give a news for official Octane support in HDR Light Studio soon. This is really nice succes for the plugin."
Wow, cant wait for it!
David_S
Sometimes, live viewer does not resize the image. Is there a solution like deleting preferences?
TBA3D_70
Would love to see a "NO UPDATE anything-switch button" in the octane dialog.
Atm -> equal, if I disable all update-possibility options in the dialog and also in the render settings -> octane regardless updating mostly every work step.
For modifying only the model without any rendering feedback, it would be nice doing it do without any octane update process in this time period.
Have problems with this update behaviors on big arch-scenes with a lot of geometry - on mac os x 10.9.1.
Hope, you can integrate this soon :)
TBA3D_70 wrote:Would love to see a "NO UPDATE anything-switch button" in the octane dialog.
hi,
pause button will disable all updates
TBA3D_70
I´ve forgotten this button :oops: Thanks for the hint!
blodge
Aoktar -
We've been trying to get Octane working with Team Render for a while now. Looks like the "Save C4D scene with assets" button still doesn't include the .HDR from my sky objects. It also appears to switch kernels between machines; on the host machine the kernel stays set to PMC, for example, and the rest of the machines reset to DirectLighting. Enabling the Kernel Override in the render settings dialog seems to work for this though. Using version 1.18a
blodge wrote:Aoktar -
thanks for info, i'll look for this
