OcDS Values in KeyMate and GraphMate
Moderator: BK
linvanchene
edited and removed by user
t_3
ha, i know. did go through the same sort of wondering where they keyframes are. then i noticed, that there are no keyframes for the daz focal distance also. then i took a closer look at the value range... conclusion: graphmate does not automatically zoom out to show a graph that is out of the current value/visibility range; you need to click and hold the magnifier button and move the mouse in order to zoom in/out, and once zoomed out enough, there is the graph, the keyframes and tcb/lin/constant all working :)
„The obvious is that which is never seen until someone expresses it simply ‟
t_3
and on a note: there is one issue when editing the keyframe graph with graphmate though; some sort of "feedback" causes new keyframes to be created whenever the _current frame_ value is edited in graphmate in a way.
this might be a bug in the plugin where it just isn't that obvious (i.e. when moving an oc cam value slider) as a new keyframe immediately replaces the old one for the current frame; will investigate further...
Return to “DAZ Studio”
